Question about Kenmore 63074 Top Freezer Refrigerator
There is an opening in the refrigerator part just under the freezer. I have water coming from it draining into the fridge section. What can be done?
    Master:
    Sergeant:
  • 385 Answers
There is a drain trough at that point, for the defrost water, that is clogged.You need to clean it out. It may have iced up.Hope this helped.
Posted on May 18, 2011
Leaks water inside from the ports or vents under freezer but in fridge
Your problem more than likely is a plugged defrost line in the freezer...The freezer goes through periodic defrost cyles to keep the coils from freezing up. The water catches in a trough pan in the freezer and flows through a drain hole to the bottom of the fridge where it evaporates. This drain hole perodically freezes up and the water accomulates under the freezer bottom until the water level reaches your vent ports to the fridge section. Open your freezer and on the bottom floor of your freezer you should see two screws near the front on either side. Remove them and then take out the bottom tray....this will expose the drain hole near the rear of the freezer compartment. You will more than likely have to remove ice under the tray in order to see the drain hole. Remove the lower back panel on the back of the refrigerator and you should be able to see the drain line coming from the freezer. Unplug the refrigerator before you begin work. It will take a little while for the drain line to thaw to allow liquid to flow to the bottom. I find a hair dryer pretty handy in speeding up the process. To verify you have unplugged the drain line you should be able to pour hot water in the drain hole in the freezer and see it come out at the rear of the fridge in tube line just above a little catch pan
Feb 08, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water is accumulating under the crispers. Will be and inch deep.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 25, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Water is getting into the refrigerator. there is
If the fridge has the freezer on top - the problem is in clogged drain under the evaporator.Whenever the defrost cycle is activated (every 6-12 hours), the water will drain not to the drain pan underneath the fridge, but into the air vents between the sections. Depending on the make/model to get to the drain line you may need either:
  • to remove the back cover in the freezer section;
  • remove the bottom of the freezer section;
  • remove the console with controls on the ceiling of the fresh food section
  • get behind the fridge, find the drain line going to the pan under the fridge remove the drain line and clean.
Good luck.
Vlad
Mar 13, 2010 | Refrigerators
My refrigerator is freezing inside the cooling section also there is water dripping inside the cooling section
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp and Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 10, 2009 | Refrigerators
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
Apr 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Water inside fridge
the water is coming from the top portion of the refrigerator section. the insulation between the freezer and the refrigerator is getting wet that is why the coldness of the freezer is transferring to the refrigerator trough the insulation foam. you can see droplets of water forming underneath the refrigerator section. sometimes you can see ice forming underneath also.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Refrigerators
Internal water leak Amana AT5518SW
King, you probably have a defrost drain port that is frozen over. When the unit goes into defrost it's running through the air damper instead of going out the drain line. Therefore you get water into the refrigerator section. You can verify this by removing the evaporator cover in the freezer and checking the drain hole. You can clear it by running hot water into it. You will have to remove all the built up ice from water that did not drain in that area...Catriver..post back.
Nov 13, 2006 | Amana ATB2135HR Top Freezer Refrigerator
Kenmore 63074 Top Freezer Refrigerator Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
