Question about Howard Miller Techtime II 625236 Clock Radio
How do you change the time zone on your Howard Miller Accuwave DS?
Press Mode then press Adjust till you get to the right time zone. Press Mode again.
Posted on Nov 06, 2013
2 Suggested Answers
SOURCE: Accuwave DS Clock
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Posted on Nov 04, 2008
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 | The Watches
I purchased an older Howard Miller clock and the clock is keeping time but pendulum is barely moving. What do I do?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick. Howard Miller Grandfather Clock
Dec 06, 2016 | Home
How do I adjust the settings on a 625-236 atomic clock
If you have a Howard-Miller 625-236 atomic clock, do you need to change the time zone only or manually set the time?
To set the time zone, press Mode (furthest left on the back of the clock) to get to the Alarm Time Mode. Then press Set (2nd from the left) to change the time zone. Then press Adjust (the middle button) to select the correct time zone. Press Mode again to exit the settings mode. To manually set the time, you need to remove the battery from the clock. Then reinsert the battery after 30+ seconds. Press and hold Set until the hour begins to flash, then press Adjust to change the time. Press and hold to quickly change the hour. Then press Set to change to the minutes and use Adjust to set the current minutes. Repeat this routine to set the seconds, month, date and year. Press Mode to exit to the Time mode.
The manual is available here: http://www.theclockdepot.com/howard-miller-625-236-techtime-operations-manual.pdf .
I hope this helps.
Oct 06, 2014 | Home
How do I change to Fahrenheit howard miller model 645706?
Go through the sequence of the time, date, month and then when it gets to the temp change it then
Aug 10, 2013 | Howard Miller 645-706 ANASTON ACCUTECH
My accuwave ds model 625-236 is stuck on the pacific time zone and will not let me reset it to EST which is where I live. How do I fix this problem. Thank you, Bhavna
Time Zone Setting
1. Press the MODE button to enter the Alarm Time Mode.
2. Press the SET button to change the time zone.
3. Press the MODE button to exit.
Apr 01, 2011 | Howard Miller Techtime II 625236 Clock...
need owner's manual for Howard Miller Model 625-259 atomic wall clock.
Nov 08, 2010 | Howard Miller 645-627 Clock Radio
Accuwave DS Clock
Nov 02, 2008 | Audio Players & Recorders
Howard Miller Techtime II 625236 Clock Radio Logo
3,761 people viewed this question
Top Howard Miller Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Howard Miller Audio Player and Recorder Expert? Answer questions, earn points and help others
