mcdevito75 here, If it is a crack and not just a scratch almost ant watch repair shop could replace the crystal (glass) a crack means replacement and a scratch might be able to be buffed out, Expect to spend $30.00----$60.00 either way.
The water resistant seal(s) in the watch case have been compromised. There is not much you can do except find a competent watch repair shop and ask them to look at it, clean it, dry it, oil it and change the seals. You might try using a desiccant in an air tight box like a Tupperware food storage container, and place the watch in the box for a day or so to see if the desiccant will pull the moisture out.
mcdevito75 here, look for a small watch repair shop in your area, or check her at fixya, bottom of the page repair services. Expect to spend $25.00 ---- $45.00 for a new crystal. (glass)
This sounds rather unusual, as flexing the wrist can pull the pins out of the lugs but should not damage the crystal.
If it is still under warranty, then take it to a local dealer for watch.
I suspect that you have a rigid strap and this puts a strain on the watch. I gave up using leather straps 30 years ago because of continual troubles like yours (a flexible bracelet will prevent this) and have never had any similar problems ever since .
If you have to pay for a new crystal, then investing in an expanding braceletshould be considered.
good after noon ! if you want to repair your watch can you bring here in my own watch center ,the exact address is ,MEDRANO WATCH and CELLPHONE CENTER located at b.laqui st.brgy.3 cuenca batangas philippines,thank you ! GOD BLESS !
