Need replace hdd on asus n73s, but not know how to open door on corpus
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Changing HDD in Asus U31JC
remove the rubberfeet at the bottomcase. remove the ram-door (bottomcase-cover). open the keybord and touchpad-locks. Remove the bottomcase-screws. remove the whole topcover by using a thin plastic-pen, push it gently in at the edges all around the topcover and lift it up. And there's the HDD.
Aug 12, 2013 | ASUS U31JC-A1 13.3-Inch Laptop (Black) PC...
My new asus n73s will not play ble-ray. Is the problem with the slimetype BD E DS4E1S. Best regards from Bottolf Loedemel
Go to my computer, right click the Blue Ray drive, click properties, click enable and update driver, click apply and save.
Aug 20, 2011 | Computers & Internet
Ctrl + Alt + Arrow Key DOWN turns video flipped upside down. I have some edistors that use this shortcut for code replication. So I would like to disabled this "video flip feature" orat least...
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key. Some computers do not have this function.
Jun 01, 2011 | ASUS Eee 4G Notebook
Replace Hard Drive
not hard remove screws pull out hard drive it is the size of a cell phone plug in new one
Apr 14, 2010 | ASUS Eee PC 1000H Laptop
PATA SATA PROBLEM
This motherboard does support SATA. Check out the specs on the ASUS website:)
http://www.asus.com/products.aspx?l1=3&l2=14&l3=225&model=754&modelmenu=1
Dec 30, 2008 | ASUS K8V-MX Motherboard
I need to install drivers on an old HDD for an Asus K8V mobo.
Hi gordonal123, installing drivers through safe mode is not recommended. If you want windows to function correctly than do a fresh install of windows. Over writing the Gateway hdd will cause you more grief. Windows registry will go nuts.
Link to download the Asus K8V drivers.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Here is what you need to do. Boot to your windows CD while using the Gateway system & hdd. Create a new partition within the free space of the Gateway hdd. (Follow windows onscreen instructions to create a new partition within the free space of hdd). (This will maintain the current windows function).
Restart windows when finished. Windows will create a second partition on the Gateway drive. Go to the Asus link above & download all the drivers for the K8V MB, onto the second partition of the Gateway hdd. Once downloaded & uncompressed into their own folders you can than boot to the windows CD & format the primary partition & install windows fresh onto the formatted partition. When finished you can install the K8V driver still located on the secondary partition. Copy & past these driver folders to your primary partition. Than use windows disk management software to erase / delete the secondary partition. (diskmgmt.msc).
When finished you'll have all the drivers for the K8V MB, no need to buy a PCI LAN card & more importantly a fully functioning windows with-out issues.
Good luck gordonal123!
Take your time.
Mike
Dec 30, 2008 | ASUS Computers & Internet
Could not detect HDD on my Asus P4B-M Motherboard
hi,
try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
Dec 22, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
My brand new ASUS ee PC notebook won't boot up. Any suggestions?
check in the bios settings if the hdd is detected..if detected,you need to re-install the windows..if not detecting,you must replace the hdd...ahh! i think the hdd for this laptop is expensive..coz i know its something special..not same like normal hdd in laptop,like ide or sata..its small hdd inside the board...half size for the 2.5" hdd sata or ide
Nov 23, 2008 | ASUS Eee PC 900 16G Notebook
Computers & Internet Logo
403 people viewed this question
David Payne
David Payne
