Question about Refrigerators
Compressor comes on then shuts off everything else works
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 20, 2011
LD451EGL no water extraction
Apparently, the fans are running, but the compressor has shut down. It could be a failed compressor, or the charge in the system could have leaked out causing the compressor to shut down.
Aug 01, 2014 | LG Electronics Ld451egl 45-Pint...
Compressor clutch not engaging
To locate the relay follow the wire from the clutch and you will find it. Do the engine fans come on when you turn on the AC? If they don't then you either have a bad thermostat (located by the evaporator) under the glove box or your AC system could be overcharged. There is a high pressure switch that will kill the compressor if it goes over 300 psi. If it comes on momentarily then shuts off it is probably overcharged.
Mar 16, 2014 | 2004 Honda Accord
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
A/C blows good cold air and everything works as it should, however when I turn the A/C on (doesn't matter what fan speed) I hear a constant clicking/ticking noise coming from what sounds like a fan
What you are most likely hearing is the compressor kicking on/off. The constant kicking could be a sign that there's insufficient refrigerant to keep the compressor running continuously without shutting on/off. Eventually, the compressor won't kick on at all, a safety feature designed to prevent doing damage to a compressor that's undercharged. Have the AC system checked.
Mar 29, 2011 | Kia Sorento Cars & Trucks
ED5NHGXMQ00 stopped working overnight. Ice maker
Clicking could be a bad starter relay if the noise is coming from the back under the unit where the compressor is. check it here Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
The clicking could be coming from a fan, one of which is near the compressor under the unit and another is in the freezer behind the rear cover inside.
The defrost timer could be clicking. This sound would come from the fridge. Part 6 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ED5NHGXMQ00&productCategoryId=0165000&brandId=1198&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00011&componentDescription=CONTROL%20PARTS&documentId=W0309019&backToLink=Return%20to%20Sub%20Components%20list
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Compressor on sxd20tw wont shut off. just cleaned
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Aug 25, 2009 | Refrigerators
Compressor keeps shutting off after 30mins or so
The system may be going into cool down mode or thermal over load if the temperature is 104 degrees fahrenheit or above since the compressor will shut down if the internal temperature reaches 165 degrees.This could also be from low oil in the compressor.
May 19, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
