Question about Garmin 010-00358-00 GPS Receiver
Cannot unlock maps on sd card - Garmin 010-00358-00 GPS Receiver
  • jhonesnaps Aug 23, 2008
    sd will not unlock
  • float666 Sep 04, 2008
    tryed photo sd card same thing happens
    New Friend:
    Problem Solver:
  • 6 Answers
Firstly, connect your device to a computer. You will find a folder in the device called 'Garmin'. In this folder will be multiple files that start with the phrase 'gmap'.
Delete the files starting with 'gmap'.
Once you have done this, re-load the courses on your device using the Garmin CourseView updater which can be found here:
http://software.garmin.com/en-GB/courseview_updater.html
Simple!
Posted on Nov 08, 2013
  • Garmin Master
  • 638 Answers
You need the unlock code to add maps to your GPS unit. If you purchased the maps through Garmin or an authorized Garmin dealer, contact Garmin and they will help you with the unlock. If you downloaded the maps from the internet from a site other than Garmin, those maps won't unlock.
Posted on Jan 07, 2009
Returned the unit
Posted on Aug 15, 2008
Garmin nuvi 200 SD card
Did you rename the file extensions? On the unit, the map file and map unlock file must be named gmapprom.img and gmapprom.unl
On the SD card they must be named gmapsupp.img and gmapsupp.unl.
Also copy your garmindevice.xml file over to the SD card too.
Feb 26, 2013 | Garmin nuvi 200W GPS Receiver
I have 2010 maps on a SD card for my Nuvi. Does
If you already have a map on your unit, you will have both maps. You may have to enable the map on the SD card. At the main menu, press the wrench symbol, then the map icon and then "map info". You should see all of your maps that are available to your unit. Make sure that the square boxes next to each map are checked. Thats how you turn on/off (selct) each map. If the SD card map isn't working, make sure it has a unlock code assigned to the map or it won't work on your unit. Also, the map file name on an SD card is different than the name on your unit. - Jim
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
Maps are locked on sd card how do I unlock them to use them?
Normally there shouldn't be a problem taking maps off of an SD card. The only time that a Garmin unit will put lock codes on maps located on an SD card is if the maps were purchased and already unlocked on another unit. If someone tries to then use those maps on a different unit the Garmin system will check to see if they have been accessed already. If they have then the unit locks them out. The only other thing that may be going on is that someone else put a password on the maps. If that is the case then you will have to get that person to give you the code.
Mar 16, 2010 | Garmin nuvi 255W GPS Receiver
Can't unlock maps on the SD card
I am still waiting for the promised free solution suggestions
Jun 12, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
Cant't Unluck Maps
The "Can't Unlock Maps" message occurs when the device detects that maps have been installed, either to the internal memory or on an SD card, that do not have the proper unlock code required by Garmin. It sounds as if what you may have done is inserted an SD card with maps on it that are not unlocked for your unit. Call Garmin; they will sell you the proper unlock code for using the maps in your unit.
Jan 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Vista HCX Micro SD Problem
Vista only recognize gmapsupp.img files.Go to www.mapwel.biz/down.htm take MapUpload software then from mapsource select maps you want to transfer to sd card.Or directly from Mapsource select Transfer and send selected map to sd card.Maps must be unlocked.
Aug 19, 2008 | Garmin eTrex Vista GPS Receiver
Pop up screen
Do you have an sd card installed with mapping data on it ( a folder named garmin)? Or a defective sd card?
I had this error with a copied map, seems to be an issue with a wrong or missing *.unl file, which is an unlock file for unlocking map data
Jun 07, 2008 | Garmin zumo 550 GPS Receiver
New Maps - Can't update unit
The new maps will be unlocked to your GPS using the code Garmin supplied you.
You will have to add these maps to a second SD card if your present card is full, or else purchase a larger card. Since all the Mapsource NT 2008 Europe maps are 1,395MB in size, you'll need to purchase at least a 2GB SD card.
Mar 27, 2008 | Garmin StreetPilot c510 Deluxe GPS...
USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
Garmin 010-00358-00 GPS Receiver Logo
375 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
