Question about Microwave Ovens
Panasonic washing machine NA-168vg3 stopped with 31 mins to go giving error code U11
U11 is inability to drain. Check your filter. Check your outlet hose. If you can blow down it, then your pump's jammed. I just found headless metal rivet type pin in the pump. Take the drain flap off, and remove the screw. This whole width panel now moves off to the left.Lean the machine on it's side, take off the black plastic plate. Remove the two screws from either side of the filer on the front. Pump is now loose. Remove the three screws on each pump and check if anything is stuck in the impellers.
Refitting is the reverse.
I know this is an old post, but someone may find this useful!
Posted on Mar 01, 2013
Panasonic microwave nn-e252w is showing error code 888. What is the code please, and how do I fix it?
There is no error code 888.
All error codes on this machine start with the letter H.
Dec 14, 2017 | Panasonic Microwave Ovens
Replace broken door latch
Click on this link to get to a web page from which you can E-mail Panasonic your question.
http://eng-na.faq.panasonic.com/
Nov 08, 2014 | Panasonic NNSN657S Microwave Oven
F14 error code comes up after heating starts and shuts down.
this is special error. You must go to the panasonic ONLINE. give your model, and ask a question for get support ONLINE free, and fix it.
God bless you
Jun 15, 2013 | Panasonic Pro II NE2180 2100 Watts...
Panasonic microwave S333 just stopped suddenly. I see on the internet that this has happened to others after about 2 yrs use. Any solution suggestion is appreciated.
Did it show an error code in the display?
If it showed H-98 or similar the magnetron has failed.
It is not a customer repairable item. Take it or have an Authorised Panasonic service centre look at it.
Jan 19, 2011 | Panasonic NN-T694SF Microwave Oven
Panasonic Microwave Genius 1200W stop working. I move a little bit electric cord and it went on again. Then I pressed one min quick reheating. It blinks and stop working. Any solution ?
Assuming that you mean the whole unit goes off as if you unplugged it then the problem sound like the incoming power//you say that if you moce the cable then it comes on untill you try to use it //replace the whole cable from plug into the machine
Dec 29, 2009 | Microwave Ovens
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
Hi there. I have a panasonic mocrowave model no. NE-1037 When i turn it on almost everytime it gives me an error warning Error code F33 How do i stop this and why does it happen? Regards
F33 is usually a code indicating a faulty ground to the control board.
The usual culprit is the top screw that holds the control panel assy in place. Remove that screw, clean around the screw hole and lightly sand the area to insure a good ground. If you have one, install a star washer on the screw, replace, and tighten really well.
That will usually fix your problem!
Jul 23, 2008 | Microwave Ovens
M# 1757 S#E14250048 Error Code F 21
That is the correct model #
Also I don't find an F21 error code in my manual also ????, Thanks for any help you can give me.
Alan
Jul 08, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
527 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
