Question about Epic 400 Mx Treadmill
I have a Epic 400mx and i did not use the mechine for almost 2 years and now few control buttons of the control panel ( start, 1 and 9 mile speed) are working and rest of the control buttons are not working or responding. it is set to manual. By the way motor is working only in 1 or 9 mile speed due to control panel issue and display and fan function is working fine.
  • desibdesi May 19, 2011
    Hi jem07 :
    When I said - control buttons are not working or responding it means all the control button of the console display / control button (Except few) . So, With this clarification is the solution still remain as it is ?
    ---Desibdesi
  • 5,603 Answers
Most of these use a membrane keyboard with silver inked conductors on plastic membranes that are pressed together through a hole in an insulation layer between the two printed membranes. When these keyboards start to go bad REPLACEMENT is really the only solution.
Posted on May 20, 2011
  • 794 Answers
Hi desibdesi,
This issue that you have is an early sign of a bad Control Board. This requires new PCB (control board). This site offers spare parts for your specific model. You may call them as well at 800 750 4766, 8am-5pm Mon-Fri CST.
Hope it helps.
Thank you for using FixYa.
Posted on May 19, 2011
  • Jemalyn Labaguis May 20, 2011
    Hi desibdesi,
    The solution is still the same.
Why doesn't it start?
epic view 550 treadmill video 2 - YouTube
? 2:08
https://www.youtube.com/watch?v=fSIuoh_bZN4
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
Epic View 550 Treadmill Review - YouTube
? 3:02
https://www.youtube.com/watch?v=kNiFOcrV9r4
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
Epic View 550 Treadmill video 3 - YouTube
? 1:59
https://www.youtube.com/watch?v=YjqgZS-1qlw
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
Epic View 550 Reviews - MyTreadmillReview.com
mytreadmillreview.com/epic-view-550-reviews-2
Jan 27, 2016 | Epic View 550 Treadmill
Speed changes on it own
speed controller is malfunctioning
Dec 11, 2013 | Weslo Epic 10pi Rear Roller For Model...
We have a 600 mx and the pad is not working, the only button working is the start, i cannot increase speed or incline it either.
It is very unusual to have no incline or walking belt operation..
Try entering diagnostic mode and do a calibration. The instructions are found under the motor cover on a tech sheet.
1: with the safety key removed, press stop and speed up simultaniously.
2: Attach the magnetic safety key.
3: press stop 1 time.
4: at this time, by pressing the incline up, the incline should calibrate, going up to maximum then back to minimum..
5: press the speed up key, you will see the numbers on the console increase. The machine should start moving the walking belt around 25-30 on the display. At 85 the belt should be running at maximum speed.
6: press speed down, the machine should stop.
7: remove the safety key. Now replace the safety key and try the machine again.If any of this procedure didn't work, I would suspect a defective console. Otherwise, the motor controller may need replacing.
Good Luck
Dec 14, 2010 | Epic 600 Mx Treadmill
My control locked button is lit on the control panel of my front loading Maytag Epic. Therefore, I cannot start a new load (which I just put in). The door easily opens and shuts as itnormally does. Any...
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. So, holding the "OFF" button will not clear it. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, Kenmore Elite or Maytag Epic series FRONT LOADER, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope this corrects the problem for you.
Mar 17, 2010 | Maytag EPIC MFW9700S Front Load Washer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Epic z front load washer will not start
Maytag service came out and told me it is control panel Part# W10217425. I washed 4 loads 1 day and came back 4 days later and got 1 load done. Then it wouldn't start and they won't replace. I got mine at Home Depot but, Maytag won't replace. They say it has to break 3 times before they will replace. After Maytag sent someone to fix and they said they had to order part and didn't know when they would be back. I called Home Depot and they overnight sent me part. Now Maytags service says they cant come back for a week and if I put in myself I lose my waranty. If you don't have waranty anymore, I found at Sears parts for $12.45 for board.
Feb 01, 2009 | Maytag EPIC MFW9700S Front Load Washer
My new Epic Z is only one month old
sounds to me like there is a short in the wiring or control board i would call the warranty company to come fix it
Dec 30, 2008 | Maytag EPIC MFW9700S Front Load Washer
Control locked light on
The button on my Epic version is called the "Cycle End Signal" button.  I pressed it for 3 seconds and the "control locked" light went off and the washer started.  This button is on the far right, just like premm said, near the "Off" button.
May 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Epic 400 Mx Treadmill Logo
273 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
