Question about Reebok New York Giants Eli Manning Jersey
I need the specs for the power adaptor for REEBOK CCS PT-600
I need a ac power adaptor
Amazon show one for about US $99.00
But you can get a compatible one on eBay for US 10.59 + Shipping
e.g. http://www.ebay.co.uk/itm/AC-Adaptor-Charger-for-Samsung-Camcorder-AA-E9-AD44-00116B-Power-Supply-Cord-PSU-/350944902138?pt=Batteries_Chargers&hash=item51b5f23bfa
Dec 10, 2014 | Video Cameras
Can I use an universal power adaptor with my western digital my book hard drive, as a replacement for the shipped power adaptor?!
Yes, if you get one that has the appropriate specs. The universal adapter needs to be able to output the exact voltage (e.g., 12V), it needs to meet or exceed the amperage spec (common units are mA and A, 500 mA equals .5 A), and it needs the proper shape/size plug with matching polarity (for example, +/- on in/outside).
Jan 28, 2011 | Western Digital 500GB My Book Pro-External...
My dlink dir600 is not flashing light, both at the power. it just keep flashing an orange light. and wifi/wlan light doesn't show any light at all. can somebody please help me?
Seems from the manual to be, that there is a problem with the power adaptor.
Haven't yet managed to find out if it's the router or the power adaptor that's the problematic part.
But do you have another adaptor with the same specs, you can try using that.
/Sebastian
Nov 01, 2010 | D-Link DIR-600 Router
Replacement adaptor and manual neededm for ironman 240r
http://fitness.manualsonline.com/manuals/mfg/ironman_fitness/430r.html
I checked but no specs on replacement AC adapter listed in manual; call the number listed in manual for part or specs.
Feb 27, 2010 | Ironman 430r Recumbent Bike
I have a Reebok Personal Trec and have lost the power cord for it. How do i replace it?
You find a dealer who keeps this product and order one or you search the net as I just did and came up with quite a few, then just narrow it down to the ones near you. It could even be available on Ebay???
Feb 04, 2010 | Reebok RL1500 Elliptical
Power light comes on but nothing else works.
There is a possibility that your plug on the adapter is the wrong polarity. See if the polarity is marked on your mixer by the power adapter jack.
Feb 03, 2010 | Vestax Pmc 280 DJ Mixer
NEED SPECS FOR POWER SUPPLY OF DDV-1100X
have the adaptor you require....model AD2910-0207 INPUT :- 100-240VAC, 50/60HZ 0.3A OUTPUT:- 5V -2A....AC ADAPTOR hope this helps....hope you can help me i have no software (drivers) for this camera. can you assist. pete
Jan 17, 2009 | Cameras
I need to know the polarity of my Hp Pavilion F1703 monitor as I have just brought a new power adaptor and before I connect up to the mains it says make sure you insert the adaptor the correct way round...
If the monitor does not have a symbol (similar to the letter 'C' with a dot in the middle), the cheapest digital multimeter can be used on the 'diode' or 'continuity' setting to check the input.
If the meter reads between 600 and 900, you are measuring the forward voltage drop of a protective diode.  Any other reading will mean that the positive probe of the meter is on the positive part of the connector.     i.e. If you are placing the positive meter lead on the center pin and the negative on the shell and it reads 600-900, then the power supply needs to have the negative applied to the center pin and the positive on the shell. If the negative lead is held on the center pin and the positive on the shell and the reading is 600-900 then the center pin is the positive input and the shell the negative.
The readings shown above mean that you are measuring the forward voltage drop of a diode meant to protect the unit against improper polarization and it will probably either die or ruin the adaptor if misapplying the polarity.
You can buy such a meter at electronics or auto parts stores for under $20 US.
Jan 11, 2009 | HP Pavilion F1703 17" LCD Monitor
Reebok New York Giants Eli Manning Jersey Logo
93 people viewed this question
Top Reebok Sport & Outdoor - Others Experts
Tony
Chris Hall
Chris Hall
Are you a Reebok Sport and Outdoor - Other Expert? Answer questions, earn points and help others
