Helpme hello have mitsubishi vs 70601 bad convergence, change ic convergence and bad.need diagram please
  • joker1979 Aug 14, 2008
    need helpme
  • 8,617 Answers
You can get the service manual for your set at the following link and it has the alignment proceedures outlined, and they will help with free tech support to explain the proceedures to you if you need it.
http://servicemanuals.vstore.ca/
Posted on Aug 17, 2008
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Tried convergance, but would work
i think you need to replace the IC convergence modules..
Jul 13, 2008 | Mitsubishi VS-70601 70" Rear Projection...
Red convergence
I suspect you have a bad convergence ic bad the letters 0n the ics start with stk replace ic you will have a good shot that will fix it. you do need to be able to solder . be careful. there are 2 ics replace both .
mcm electronics for parts
thanks jay
Jun 01, 2008 | Mitsubishi VS-55609 55" Rear Projection...
My tv picture is all screwed up
Your convergence ICs are bad STK392-110 you can get new ones for about 10.00 each. They are located on the left side of your chassis a large heat sink. They will need to be soldered in. Also check the resistors right next t the heat sink. Sometimes 1 or 2 of them go out along with the ICs.
Jan 19, 2008 | Mitsubishi VS-70601 70" Rear Projection...
Convergence no adjustment
There are black in color circuit protectors in the set that have blown because of the bad convergence IC's. You will need to measure the voltages on the ICs and make sure you have the correct plus and minus voltages. There should be about + and - 24 volts on each IC. I'm afraid the only way you will know what voltage are what and where they should be would be to get a service manual. i am sorry i do not have this model to share with you. Good Luck.
Apr 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Convergence IC
The convergence IC's are black in color with white lettering on them and will start with STK. These IC's will be standing up and be about 2" X3" in diameter. These IC's will also be mounted up against a large metal device called a heat sink. good Luck
Apr 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
