Question about Pool & Spa
I have a emerson 1563 spa motor and need a new terminal board, anyone know where I can get one or have a cross reference number for it,
  • 1,383 Answers
Search your area for YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING .he might have one to give you .pictures are nice to have. jay
Posted on May 26, 2011
Where can I find a diagram to fix a pump K55MYGRD-8367
this can be a hard pump to service. but you can remove the front pump housing and see if you can remove the impeller by hand, the back of the motor will have a screwdriver slot in the shaft to hold the rotor still while attempting to unscrew the impeller. after removing impeller you will need to remove the 4 thru bolts this will allow you access to the ceramic portion of the shaft seal assembly.
replace all needed parts and reassemble. never run pumps dry always prime the pump with water.
doing this job can save you a bunch of money and usually cost about $150 at my shop.
Jay the pool pump repair guy Longwood FL.
Jun 26, 2017 | Emerson Pool & Spa
I have an emerson 1563 spa motor, fitted the hottub today and found that the circulation pump worked but slow, and slow;y stopped and got very hot. on stripping the pump down found the impellor had so
try clearing the debris, and the impeller should rotate about a full turn with a twist of your wrist. if it still doesn't run properly STOP.
the pump might need to be serviced by a pro, i don't recommend servicing these as the are fragile to say the least and expensive to replace . let a pro do it !
give me a vote if'n I was of help.I love praise, it's the fuel that keeps me fix'n yer stuff.. Jay
Nov 16, 2014 | Pool & Spa
I have an Emerson spa pump 1081/1563 and the volute is cracked but the pump works. Where can I find a replacement or can it fix the volute myself?
Go to emerson.com then enter model and look for the parts section, you can find repair manuals parts etc.
Jun 09, 2014 | Pool & Spa
Spa pump leak
Failed Mechanical 'Pump Shaft Seal'
Apr 13, 2014 | Emerson Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
Emerson 1081 1563 R63MWENA-4727
should tell on old motor if tag is gone contact manufacturer
Oct 30, 2013 | Pool & Spa
Emerson Motor model T55CXCAS-1179 230 volt
There should be a wiring diagram sticker on the motor. If not, let me know at questions@oskopoolnspa.com
Jun 03, 2013 | Emerson Pool & Spa
I'm trying to find a seal kit for a Emerson spa pump Model #T55MWCCE-1208
The seals are specific to the Jacuzzi pump housing not to the Emerson motor. Most Jacuzzi pumps use the PS-200 or PS-201 seal (some have it listed as AS-20X) here is a Pump Seal Cross Reference.
Jul 25, 2012 | Emerson Pool & Spa
I need to purchase a Emerson 1563 spa motor. Cat. 9352-9303 Model K55MYGRD-8367 hp 1/15 and 230 volts. Can you help me?
This place has them:
http://www.affordablespasandparts.com/Aqua-Flo-CMCP-R0-1-15-hp-230v-1-spd-02593001-2010GK.htm
Jun 27, 2010 | Pool & Spa
Pool & Spa Logo
301 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
