Question about Cycling
Does the blaster take two stroak or straight gas
  • Hugh Parker
    Hugh Parker May 19, 2011
    Could you please give more information (ie: make, model, simple description)
  • 76 Answers
Two stroke mixed gas (oil and gas)
Posted on May 20, 2011
I have a 2004 Yamaha blaster , it Won't start and is backfiring when I give it gas when I kick it ,rode like a champ the other day now won't start
Hi, Anthony and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
8. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
9. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
10.. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
11. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2, TPS, ETP, IAC,or BAS).
12. Faulty neutral, clutch lever, or kickstand safety switch.
13. Faulty fuel pump fuse or relay.
14. Tilt sensor needs a reset.
15. Security system not disarming alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
03 blaster won start
HELP 01 BLASTER WILL NOT START Yamaha ATV Forum
How to start quad or dirtbike Troubleshooting guide
https://www.tradebit.com/filedetail.php/277824617-yamaha-blaster-yfs200p-1988-2006-service-repair-manual
http://www.yamaha-motor.com/assets/service/manuals/2001/lit-11626-14-09_246.pdf
Apr 29, 2016 | GAS Motorcycles
Tip
How To Install Your Sound Blaster Audigy, Audigy 2, and Audigy 4 In Windows...
This download is a driver and sound card applications providing Microsoft® Windows® 7, Windows Vista® and Windows XP support for Creative Sound Blaster® Audigy® series of audio devices.
This download supports the following audio devices only:
  • Sound Blaster Audigy including Platinum and Platinum eX series
  • Sound Blaster Audigy 2 including Platinum, Platinum eX, and Value series
  • Sound Blaster Audigy 2 ZS including Platinum and Platinum Pro series
  • Sound Blaster Audigy 4 Pro and Sound Blaster Audigy 4
  • Sound Blaster Audigy 2 ZS Notebook PCMCIA
DO NOT install this driver for Sound Blaster Audigy LS, Sound Blaster Audigy SE, or Sound Blaster Audigy Value.
Included in this download:
  • Creative Audigy, Audigy 2, and Audigy 4 Driver 6.0.1.1377
  • Creative ALchemy 1.41.02
  • Creative Audio Console 1.31.10
  • Creative Graphic Equalizer 2.00.65
  • Creative Dolby Digital Live Pack 3.00.03
  • Creative DDL License Activation 1.00.04
  • Creative MediaSource DVD-Audio Player 2.00.78
  • Creative EAX Console 3.00.56
  • Creative SoundFont Bank Manager 3.21.00
  • Creative Speaker Settings 2.00.60
To install this driver:
  1. Download the Audigy_SBAX_PCDRV_LB_2_18_0017.exe file onto your local hard disk.
  2. Double-click the downloaded file.
  3. Follow the instructions on the screen.
on Feb 26, 2011 | Computers & Internet
Wheat eater
If you put mixed gas in it with oil and it takes straight gas no damage if other way around its junk Put straight gas in it and a new spark plug should run To be honest think you did the reverse put straight in when should be mixed not any trimmers out there that take straight gas unless 4 stroke
May 13, 2013 | Garden
Started with straight gas- can it be flushed and restarted with gas /oil mix?
Yes you can dump out the straight gas and mix some two cycle fuel mix I would mix it a little rich like 32 to 1 thats eight ounces to two gallons of gas but if you ran it with straight gas for a long time it wont help
Nov 07, 2009 | Echo Inc. 25.4 CC Backpack Blower
Changed reed valves drained out old gas put in new gas now it won't start. It's a 2004 Yamaha Blaster
hi mate on the carb there are 2 screw one for mixture and one for idle you need to unscrew the mixture screw 1/2 of turns and see if this improves 1728936.jpg
Aug 29, 2009 | 2004 Yamaha YZ 125
Chranks hard,won't start
you need to adjust the valves with the cylinder 1/4 inch below top dead center to get the decompression lobe to function right during cranking.
Aug 07, 2009 | Garden
No water pressure
Plugged in but does not work
Nov 12, 2007 | Karcher 2500 PSI Pressure Washer
Cycling Logo
23 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
