Question about Saeco Incanto Sirius Fully Automatic Coffee Maker Stainless/Black
Water does not dispense from the arm, instead it drips into the plastic drip tray (I have cleaned the steam wand and there is no clog). Coffee can be made, and is hot, but instead of filing up my cup fully, 1/4 of the water now goes into the plastic drip tray. I also do not get steam from the wand. Any idea what the issue may be or how to repair it?
  • 2 more comments
  • vette1900 May 18, 2011
    Hi, thanks for the reply, but this didnt help much. I had already descaled the machine, and unfortunately the problem continued. Second, unless I'm familair with the parts needed for repair, the Cerini part list & assembly does me little good.
    What I can add is that after the machinge goes through a cleaning rinse, I've pull out the brewing unit and noticed that water is coming out of the white spount with the 2 orange o-rings.
    Any thoughts?
    Thanks.
  • vette1900 May 20, 2011
    The orange o-rings actully look OK. I've lunricated them regularly and they don't show any signs of wear & tear - no cracks. Is it still possible that they may be causing the leak?
  • 710 Answers
Hi vette1900,
First, have you descaled your machine?
If you have, you may have either a clog further in from the wand or one of the seals or the valve is leaking.
Sorry to say, Saeco does not make their coffee machines to be user friendly when it comes to repairs.
If you want to attempt checking further into your machine, here is a webpage with a parts breakdown for you to see: >>>> http://www.cerinicoffee.com/custompages/Diagrams/Saeco_Parts_Diagrams/Fully_Automatic/incantosirius-SUP021YADR.pdf
You can disassemble the steam wand and pull it out to look for a blockage or leaking O-rings or valve. If you need a new valve, parts guru has them along with installation instructions: >>>> http://www.partsguru.com/MaintenanceofEspressomachines.html
If you do not have a repair facility near you, partsguru.com can repair it for you. Here is there repair site: >>>> http://www.partsguru.com/default.html
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 18, 2011
  • 1 more comment
  • Handie Andie
    Handie Andie May 19, 2011
    Ok, if you cleaned those tubes thoroughly, then I imagine the O-rings are leaking. Before you put new O-rings in (than can be gotten at any hardware store or auto parts place), try putting a touch of vegetable oil on them to get them to seat when you put it back together. If that doesn't work, then replace the O-rings.
    Good luck to you,
    Handie Andie
  • Handie Andie
    Handie Andie May 20, 2011
    Hi vette,
    Can you see #74 on the diagram I gave you? This is the seal for the wand. This is what I think may be bad and need replacing.
    And, yes, O-rings are compressed in order to provide a seal. After time, they stay squashed and lose their resiliency.
    If you want to replace the seal, #74, I will provide you with a website that sells them. I just found out Cerini Coffee is out of them..... Need to find another place that has one.
    Please check back,
    Thanks,
    Handie Andie
  • Handie Andie
    Well, I've been searching the internet and can't find anyone who carries the part. I think your best bet would be to send it in for service.
    So many of the websites don't carry the part that I'm not sure who to send you to. You could try contacting the people at this website: >>>>http://espressocare.com/serviceHomeUnits... <<<< or you could contact Saeco at www.saeco.com
    I imagine Saeco would charge more.
    Good luck to you!
    Andie
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
Delonghi Magnifica My steam arm drips when I make coffee.
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
We have a Gaggia Syncrony Logic that is just over two years old. After each brew cycle, the puck is successfully ejected but water and some grounds flow out under the drip tray instead of into it....
Hi
Check the drain behind the brew unit. There is a pocket below the injector that can plug up and cause water to drain under the drip tray. Check this first. Stick you finger in the pocket and see if there is water in it. If there is, the drain below and to the right is plugged and just needs to be cleaned.
Dec 09, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Significant leak into drip tray when brewing and using steam/hot water
run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Dec 01, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Incanto Sirius Fully Automatic Coffee Maker Stainless/Black Logo
91 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
