Question about LG Flatron L1515S 15" LCD Monitor
I am using LG Flatron L1515S LCD moniter, Can you please help me that my moniter is flickering in 1024x756 if it is in 800x600 its not flickering but i was not able to work in 800x600.
Can any body tell me hether it require any drivers.
    New Friend:
Monitor display center line problem
Posted on Jul 17, 2010
SOURCE:
I need the drivers of flatron w1943tb....
LG Flatron L1515S doesn't need a driver to be installed on Windows Computer or any other systems. If you have problem with it, then it should be your graphics driver that you would need to install.
Similarly W1943TB-PF doesn't need driver. (I am not sure which one among the two LG Flatrons you have since your question is tagged under the LG Flatron L1515S while your problem refers to LG Flatron W1943TB.
If you have other problem, let me know with more details.
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | LG Flatron L1515S 15" LCD Monitor
LG Flatron l1515s which is giving Out of Range 64.0kHz / 60Hz and can not even give setup menu. Please help.
This is not a setting on your monitor. It is a setting on your operating system. The display settings needs to be set to a 60Hz refresh rate.
Hook up your old monitor and right click on desktop --> properties --> and then to display and advanced settings. You can then set it to proper refresh rate and plug the new monitor in.
Mar 28, 2011 | LG Flatron L1515S 15" LCD Monitor
I need to open LG FLATRON model L1515S Back cabinet
I use flat blade screw driver for separating the front and the back.
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L1515&kategoria=monitor&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 17, 2011 | LG Flatron L1515S 15" LCD Monitor
Omi have lg flatron 1941s lcd monitor its OSD locked how to solve it
i have a problem with my lcd a small area is permanently black a scratch like lines less than 4 mm X3 mm size
Sep 17, 2010 | LG Flatron L1515S 15" LCD Monitor
LG Flatron L1515S 15" LCD Monitor Problems & Solutions
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 18, 2010 | LG Flatron L1515S 15" LCD Monitor
Power ON, no display ,when switch off and on screen display for 1 or 2 second, again goes blank. model= LG Flatron -L1515s
check the power cords and the video connectors. if it's ok, then it could be a problem on video card
Feb 17, 2010 | LG Flatron L1515S 15" LCD Monitor
OSD LOCKED UNLOCKED Problem
it may be in demo mode, try presing "engine" and selecting normal.
Or press menu and select setup and scroll down to factory reset.
Aug 18, 2009 | LG Flatron L1515S 15" LCD Monitor
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
LG Flatron L1515S 15" LCD Monitor Logo
414 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
