Question about Canon Cameras
I have a canon sd750 camera and I can't figure out how to put it on rapid shutter
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
SD750
See page 68
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 15, 2008
Hello I have a Canon SD750. The Camera turns on, but the lcd is black and if I take a picture nother shows up. Please help. I have not had it for long. Thanks.
Melinda, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 13, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon PowerShot SD750 digital camera screen suddenly turn black(dark ), I can not take picture because there is no image shown on screen. I still can record sound on video,but no image. what is going...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A.
Dec 26, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Power Shot SD750 screen went black. Read solutions, not sure what TV mode is? Is it same as video mode?
Tv is "shutter priority" mode. The Canon SD cameras do not have that mode. Instead see Fix 5A of the below link. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
What makes the screen stay black when camera is
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't help...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 14, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Battery door replacement
Does this mean you have a replacement door already?
If so, you will need to figure out how the camera comes apart. This is not always easy to do. I suspect there will be screws or snaps hidden. Improper dis-assembly will cause damage to the case and/or finish.
I would contact Canon and ask if there are any repair shops near you that they could recommend.
Joe
Mar 08, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How do i turn on the date stamp on my Canon Powershot SD750 so that the date prints on all my pictures?
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
Jan 31, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
The shutter continues to click in rapid concession Canon 20d
Check to make sure that you don't have it set on continuous. Check the lcd display and see if the shutter icon showing a mulitple as opposed to single frame image.
You should be able to choose between single, mulitiple and timed shutter releases...
Sep 08, 2009 | Canon EOS-20D Body only Digital Camera
I have a focusing problem with my SD750. Photos are coming out slightly blurry when I press the shoot button quickly now - but it's OK when I press the buton very slowly. Is there a way to correct this ??
It sounds more like camera motion than a focus problem. Make sure you don't move the camera when you press the shutter button. It's easy to **** the camera when you press the shutter button quickly.
Jul 12, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon power shot SD750 can't take pic with flash
Hi
Your flash is defective, or the mainboard is defective and cannot control the flash. The only way to figure out which is the problem is to start by replacing the flash and see if it works.
You can probably find a parts camera online and use it to fix yours, if not let us know and we can help. We are an affordable digital camera repair business.
Thomas
Owner- Darntoothysam com
Apr 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon EOS 20D shutter error
Hello - I figured it out. I had the exact same problem. The shutter failed and it had to be fixed by Canon. Apparently that happens after the shutter fires so many times (like a click-count on a printer). I just got my camera back and it's doing awesome now.
Feb 19, 2009 | Canon EOS-20D Digital Camera
Cameras Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
