Question about Garden
I HAVE A SHUR-DRI WATER HYDRANT AND IT WAS WORKING FINE ONE MINUTE AND NOT THE NEXT. SUPPOSED TO BE ABLE TO REPAIR W/O EXCAVATING. i CANNOT FIND ANYTHING ONLINE ABOUT HOW TO REPAIR. GUESSING......SEEMS LIKE STOPPER CAME OFF AT BOTTOM. WOULD REALLY LIKE TO FIX W/O EXCAVATION........HELP IS APPRECIATED.
  • 10865 Answers
SOURCE: clayton mark freeze proof hydrant
You are going to have to dig and replace the entire freezeless faucet. sounds like it either froze or rusted off.
Posted on Feb 27, 2009
  • 9 Answers
SOURCE: kubota kh 91 excavator, blowing lots black smoke
If the Air filters are NOT restricted in any way and it's not skipping ( indivual cylinder problem ), check the small return line coming from the injectors going to tank for blockage. This will be a small line probably held on with a worm gear clamp. Good luck
Posted on May 19, 2009
udesh99
  • 97 Answers
SOURCE: how to reset the service light on a JCB JS 130 Excavator
Press "SET" & "MODE" Keys Both 20sec. (After Menu Coms)
Select "Service off" By Press Arrow Keys
Then Press "ACK" Select "Service on" Position by pressig Arrow Key & Press "ACK"
Posted on Jun 05, 2009
  • 7 Answers
SOURCE: Excavator track needs to be put back on
after the idler is pushed all the way back into the frame.try to put some wood blocks under the track to remove all the slack.use the bucket to push as much of the bottom section under the bottom rollers.use a heavy chain and pull up and over the top of the roller.when you get close you can use the drive to walk it the rest of the way.if it still doesnt go you may have to break the track at the master pin. this is usually marked with a small hole drilled in the end of the pin.heat and beat the pin out,break the track.pull track over top rollers and make ends meet on top of the srocket.use a chainfall to pull two halfs together and line them up.drive pin back in and your all set.
Posted on Jul 02, 2009
  • 4 Answers
SOURCE: 330 excavator with a c9 cat engine, heavy SMOKE
At the time you made all the above repairs, did you replace the "throw away" turbo charger? The turbo charger commonly sucks oil, and it is not repairable.
Run it without the inner & outer air cleaner. If it isn't the turbo, run the injector cut out test. If the injectors are ok, then you need to replace the injection system hydraulic pump, which is also unrepairable.
Posted on Apr 23, 2010
Repairing 3 leaky frost free Clayton Mark water hydrants?
No, you don't need to know how deep they are.
Usually the rubber tip called a plunger is all that needs to be replaced.
You'll need to know your model number or easier is to just bring the old one with you to the store.
On this page is an excellent diagram of a Clayton Hydrant.
Clayton Mark Yard Hydrants parts
Here is a video of how to take one apart.
Oct 03, 2016 | Washing Machines
Why does my tub hot and cold water have a rust color for the first 5 seconds ?
Sediment from your water source have the same issue here call the water company tell them you need your hydrant flushed. They will send someone out to open the hydrant to pull the sediment out of the water lines.
Mar 22, 2015 | Washing Machines
Where can Iget impeller #16622B010 for a shur dri water pump
I can only help on a Honda 50hp 2003. Any Honda center or parts center. That's all I know. JMC
Jun 09, 2014 | Honda Water Pump Impeller Outboard 35, 40,...
What is the difference between the Simmons Yard Hydrant 850 repair kit and the 850SB repair Kit? The pictures of the parts look the the same. The price is a few dollars different. My hydrant was new...
The 850SB is a lead-free hydrant and the 850SB repair kit maintains that lead-free build.
The two repair kits are identical beyond that lead-free status. If you have the 850 hydrant, the 850 repair kit will be fine. Since the rest of the hydrant may contain lead, there is no advantage to using the lead-free parts. (If you live in California, you may need to get the 850SB kit. The rules for products with lead in California are a bit different than those in other places. So the company only sells the lead-free model there.)
I hope this helps.
Sep 16, 2011 | Sport & Outdoor - Others
Can the air filter be washed in soap and water
TURPENTINE CLEANS IT BETTER IF YOU DO SOAP AND WATER MAKE SHUR ITS DRY AND THEN RE OIL FILTER
Jan 23, 2011 | Husqvarna 450 e-series 18" Chain Saw
I have a Shur-dri SD-106 pump. I am looking for a source to purchase replacement impellers. Please advise
call 888-987-8677 this a division of pentair they make shur-dri pumps
Sep 15, 2010 | Plumbing
Where can I find a replacement impeller for a Shur-Dri SD-106 pump?
Connect to the internet and type;
http//www.merchantcircle.com/business/Shur.Dri 419-289 1144.
This is where you can find your ShurDri Pump parts.
Oct 25, 2009 | Plumbing
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Garden Logo
160 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
