Question about Maytag Dishwasher
How is the "SPRAY ARM
    Master:
    Sergeant:
  • 385 Answers
It's attached by the center post. You have the unscrew the center post.
Posted on May 18, 2011
The upper spray arm came detached, how do I reattach it?
On my dishwasher, this arm attaches with a huge gray plastic screw. If it comes loose, you'll usually find the spray arm sitting in the bottom rack, but the screw falls down to the bottom of the tub.
The spray arm has a hole that goes all the way through its center. One of these holes is larger than the other, so the arm will only attach in one direction. Most of the spray holes on the arm face "up" when installed.
Slide out the upper rack, position the spray arm on its pivot, then insert the screw and turn clockwise to tighten it. The arm should spin freely.
If this arm isn't attached, none of the dishes will wash well (due to a loss of water pressure).
May 21, 2015 | Bosch SHU9915UC Dishwasher
Top rack of dishwasher not getting clean
The most common problem with the top rack not getting clean, is either the middle spray arm is broken and not turning (if equipped) or on some model the pop up spray arm is either clogged with debris and not turning or the pop up part is broken. Make sure to check the spray arm under the top rack, if your has one, to make sure the feed tube is attached all the way from the side to the spray arm part. If part is missing or broken, as this is often the case, you will need to determine which parts are either missing or broken, and replace those parts. If the pop up part is missing or broken, this piece comes usually with the bottom spray arm in an assembly. Your owners manual should be able to direct you further.
Good luck.
Aug 11, 2010 | Dishwashers
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
Water not pumping to upper spray arm
First,
See this link for a picture of the upper spray arm and manifold assembly.
http://www.apwagner.com/index.php?main_page=model_lookup&model_num=KUDP02IRBL0&model_id=163723&diagram_id=380403
Referring to parts 1, 6, and 9, make sure everything is attached, secure, and lines up when the upper rack is pushed back into place.
It's possible the pump is obstructed and not delivering water to the upper arm, but the more likely cause is a displaced upper arm feeder tube. If no luck, start checking for obstructions in the feeder tube, manifold and the spray arm.
Mar 14, 2010 | KitchenAid 24 in. KUDP02IR Dishwasher
Center water tower came apart
There have been many versions of the spray tower used over the years. If you have the model HDA3400G which you posted under, you should get a part number WD22X10008 which is the lower spray arm and tower assembly. By looking at the new part, you will see how a couple tabs hold the part on, and can figure out how to remove the old one with a flat blade screwdriver (or two). If you have a different model, please post the exact model number. The model number sticker is generally located on the left side wall of the tub, right by the front.
Apr 19, 2009 | Hotpoint 24 in. HDA3400G Built-in...
How do I open the sprary arm
the plastic screw is not holding it down. First disconnect the white tube in the back of the bottom spray arm.Now turn the stub part clockwise. and the spray arm should pop off...
Jul 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Installing part
there should be a clip half way up the back and on the top. release those and the old tub should come out with out to much difficulty. the peice that attaches from the feeder arm to the lower spray arm turns clock wise and lifts out. the lower spray arm will unscrew if you use a pair of pliers.
Sep 24, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Maytag Dishwasher Logo
44 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
