Question about Garmin GPS
My nuvi 760 - when mounted and plugged into the lighter of any car - is not automatically coming up like it used to. When turned on it displays the low battery warning and goes off. I'm thinking it is the cord from the base to the car??? Where would I purchase such an animal and could it be something else? Thank you for your assistance, Emma
    President:
  • 1,514 Answers
It could be the fuse in the charger cord. On the end of the plug, that goes into the cigarette lighter socket, there's a ring, usually silver coloured but black on some. Unscrew the ring and the plug will come apart. Be careful not to lose the silver tip. Take out the fuse and replace it with another which can be got from car accessory shops or most shops that sell garmin satnavs.
If this doesn't solve the problem you can get a new charger lead from https://buy.garmin.com/shop/shop.do?pID=1371
Posted on May 19, 2011
My car charger will not charge battery in garmin Nuvi 760
The fuse may be gone in the charger. There's a ring, near the silver tip, of the plug that goes into the cigarette lighter. If you unscrew the ring the plug will come apart. Take care not to lose the silver tip as it may fall out. Replace the fuse and it may solve the problem.
Feb 28, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
My nuvi 760 doesn't charge in the car. is there another way to charge it?
It can be charged from a computer. Connect it to your computer with the mini USB lead and it will charge. It takes about 8 hours compared to 4 hours with the car charger or with a mains charger.
If your car charger isn't working it's likely that the fuse is blown. I presume you checked the cigarette lighter socket first and that it's working. If not try something else in the socket and make sure that's not the problem.
At the end of the charger lead plug, that goes in the cigarette lighter socket, there's a ring. Unscrew the ring and the plug comes apart. Be careful not to lose the silver tip. When the plug comes apart you'll see the fuse. You'll get a replacement in any car electrics shop or anywhere that supplies satnavs. I hope this solves your problem.
Jan 08, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
My Nuvi 760 doesn't hold a charge and keeps shutting off when charging in car outlet. Thanks for any help you can give me.
Check the car charger cigarette lighter adapter plug first, at the silver tip end of plug it has a fuse, Unscrew the silver tip CAREFULLY its spring loaded and check fuse...
Nov 06, 2010 | Garmin nuvi 750 GPS Receiver
Nuvi 760 will not take charge
I don't know which of the three ways you're trying to charge - car cradle, via USB cable to a computer or via accessory AC adapter. An 18 month old 760 should still have a good battery.
If you are using your car cradle to charge consistently, use one of the other methods and allow the 760 to charge for 8 hours. Use of the car cradle can cause the 760 to stop taking a charge after a while, and switching to one of the other methods should "refresh" the internal battery. Since the AC adapter wasn't included in the box, the USB cable method is likely your only other choice. While connected to your computer, you should download & update the 760's firmware. It's fast and free - and could solve other potential issues. Get the WebUpdater software direct from Garmin.
It is also possible that the fuse in the cigar lighter plug has opened. Disassemble the the plug to check for and replace a blown fuse.
If unable to get the 760 to accept a charge, you might need to replace the battery. There are several sources for batteries - but a free call to Garmin Support should be your first move.
Please rate this reply and good luck!
Jun 10, 2010 | Garmin Nuvi 760 Car GPS Receiver
My Garmin will not start up.
it sounds like your battery within the GPS Unit is died. You need to charge it somehow. Keep it connected to the car charger for around 30 mins and unit should turn on. Do not keep it on while it is being charged
Oct 18, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin Nuvi 760
I have the same unit. It comes with a trial subscription and then there is one time fee. The traffic will ONLY work when it is plugged into a power source in the car.
Remember to turn off the unit before you disconnect the cable. Otherwise the GPS unit will stay on and drain the power.
May 21, 2009 | Garmin Nuvi 760 Car GPS Receiver
Charging the battery in Nuvi 760
1) Check the cigarette lighter is working by plugging in the lighter unit and see if it gets hot. If it doesn't then it is possible the fuse has blown.
2) You can plug the unit into a PC using the USB cable and if there is a fault you will get a message on the screen about 'USB over-current' but it shouldn't damage the computer.
If it runs/charges using the PC and (1) is OK then you may have a problem with the cigarette lighter - cradle cable or a problem with the cradle itself.
HTH
Peter
Jan 24, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Assembling nuvi 760
Attach the window mount to your GPS unit ...it clips into the bottom. Insert the power supply into the mount on the right side. Of course plug it in to your power supply in your vehicle that is hot or turn on your cars power supply
Dec 08, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
When I attach my garmin nuvi 760 to the car mount and plug it in the car charger it will not power off and on when the car turns off and on. For example if I turn the car off the garmin continues to charge...
This is telling me that your cigarette lighter socket has +12VDC applied to it all the time EVEN when the ignition is turned OFF. This is not the fault of your Nuvi. On some cars, like Hondas, the cigarette lighter socket powers off when your ignition is turned off.
If you want it to turn off with the ignition, then you will have to power it from a +12VDC source that is controlled by the ignition.
- Jim
Dec 04, 2008 | Garmin GPS
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
GPS Logo
62 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
