Question about Brother MFC 6490CW InkJet Printer
I am still trying to scan 11x17 and I sent it up in control center but still not working right it scans 8.5x11
  • 656 Answers
CHANGE CONTROLCENTER CONFIGURATION
1. Open ControlCenter. START -> (ALL) PROGRAMS -> BROTHER -> XXX-XXXX (Model of machine) -> CONTROLCENTER. An icon will appear in the system tray by the clock. You may have to click this icon to launch the program.
2. Click CONFIGURATION -> SCAN -> FILE (or any other scanning option youare using)
3. Under Software Button, change Document Size to LEDGER 11 x 17 in.
4. Under Device Button, change Document Size to LEDGER 11 x 17 in.
5. Click OK
6. Place document on the Brother machine.
7. To initiate the scan, left click on FILE (or any other scanning option you selected in step 1). This issue should now be resolved.
Posted on May 18, 2011
Heater controls stop working and rear defrost inop and the park assit not working and we tried to program a keyless entry remote that didnt work eathier tried that and everything stop working
Did you check fuse's in fuse block center console ? Fuse #26 IGN3 / HVAC 10amp . Do you know what I'm talking about ?
Fuse Block - Center Console
Inside of console, behind the right console access panel
What did you do jump terminals in the DLC ?
You need a factory scan tool to program keyless entry remote .
  1. Install a scan tool.
  2. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs.
  3. Press the START soft key on the scan tool.
  4. Important: The scan tool must stay connected until all of the transmitters are programmed.
  5. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.
  6. Repeat the previous step in order to program up to 4 transmitters.
  7. Remove the scan tool.
  8. Operate the transmitter functions in order to verify correct system operation.
Oct 09, 2016 | 2004 Buick Rendezvous
Will not scan documents to file
Check the custom settings of control center. Click on control center 2 to open the scanning software. Right click on the button you are trying to scan with and look at the settings. Notice boxes for the default location of the files when sent. You can also indicate whether the program asks where to save it before it scans the document.
Feb 28, 2011 | Brother Office Equipment & Supplies
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
S. Mohan, Chennai, India
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
I have a Brother MFC-6490CW and I want to scan paper that is 11x17 and the manual says that i have to set my glass size. However, they say to push the Scan button and then the Scan to Media button...that...
You will need to open the control center program which is installed when you install the printer on your computer.
Start, all programs, Brother, control center. Click on configuration then scan then file. There are two tabs at the top, change the paper size at bottom of each to ledger and press ok.
Dec 13, 2009 | Brother MFC 6490CW InkJet Printer
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
Parts of page being scanned are cut off
Whcih version of CapturePerfect you are using?
I use ver 2.0. In the settings page select scanners maximum. In the 'advanced' select auto detection. Then whatever size of the paper guides you choose, that will will be the width and ofcourse the length is automatic. There is a sensor under the paper guide, and it detects the paper width. Any rotation chosen will be after scanning the required size.
Jul 20, 2009 | Canon DR-5010C Scanner
Want to change default settings for scan
change the size, then utility/counter - > choose user settings - initial settings and use current settings.
should work,
May 27, 2008 | Konica Minolta bizhub C351 All-In-One...
Scanning
My Photosmart 2575 v has worked fine as well for over a year and now it won't scan. I get the same message: "Refer to device documentation to troubleshoot". I ran all updates and they said I have them all and everything is working perfectly. It's not though. I still can't scan. I tried their work-around by opening paint and then acquring image from the scanner but that does not work either.
Apr 30, 2008 | HP Photosmart 2575 All-In-One InkJet...
Brother MFC 6490CW InkJet Printer Logo
629 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
