Question about Broksonic CCVG-3276 32 in. LCD TV
I have a Broksonic ccvg-3285. It is a 32" LCD +
  • 11,361 Answers
You may have 24vdc power supply problem, bad backlight inverter board/s, main board not sending out signal to turn on the 24vdc supply and the backlights board, bad T-CON board.
Please try and read the link below to get more understanding.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on May 18, 2011
Testimonial: "This information seems key and i will revise the device considering this information.. thank you so much. i will check all of this as soon as i can. "
  • 1 more comment
  • Bud Martin
    Bud Martin May 18, 2011
    By the way, I try looking for the replacement boards so you will know what the boards look like, but not much luck. I know that BROKSONIC has the TV's made by other OEM, they just put BROKSONIC name on the TV.
    Can you post the pictures?
  • Bud Martin
    OK, this TV uses LED backlights, not CCFL, that is why you do not see the big backlights inverter board.
    Per BROKSONIC WEBSITE http://broksonic.org/MainCCVG-3285.htm
    Is it still under warranty?
    LED backligts and circuits suppose to last a lot longer, use less power, run cooler than the CCFL type backlights. I guess it is not true, so sad.
  • substance_v May 22, 2011
    as soon as i get a chance to get that unit back in my hands i will post images on the insides... i do believe there are two cages in the unit one cage houses the power suppy and tcon... i believe below this cage is the converters.... i do doubt that the unit is indeed a LED device.. it was manufactored in 2006. Again, once i get a chance to look in the device i will take some snapshots.. ... Thanks for researching as much as you did. much obliged.
When you turn tv on it slowly then gray and green light on left side comes and then tv turns on and off and no picture.
Posted on Jul 09, 2011
How to know what power cord to buy
Just specify the model number to this set to its authorized dealer. They can provide it to you.
Jun 22, 2013 | Broksonic TV
Broksonic 19 inch CCVG 1935 - no sound, no picture, just a blue screen
Blue screen means either no signal (if unit has rear connections hook a DVD etc to one and go to that input and see if it works) Or the blue may mean set is in shutdown----5 months old and it should still have a warranty?
Apr 23, 2012 | Broksonic CCVG1935 19 in. LCD TV
I need a code and instructions for my one for all urc3220 remote control for a broksonic tv
  • Find the programing code for the device's manufacturer in the manual.
  • Turn on the device you are programming the URC 3220 remote to control.
  • Press the "TV" "DVD/VCR" or "CBL/SAT" button on the remote.
  • Press and hold the "SET" button until the red LED blinks two times.
  • Release the "SET" button and type the manufacturer's code. The LED will blink twice to confirm the entry.
  • Aim the URC 3220 at the device and press the POWER key. If the device turns off, the code worked. If not, repeat Steps 3 through 5 using the next code on the list.
  • Known Broksonic codes are 1112, 1432, 2112
    Jun 20, 2011 | Broksonic CCVG-3276 32 in. LCD TV
    Cracked screen on my 37"" flat scrreen broksonic
    Unfortunately there is nothing you can do to repair the screen, you will need to get a replacement screen & this can be just as costly as purchasing a new TV so it might not be economical to get it repaired
    May 03, 2010 | Broksonic CCVG-3276 32 in. LCD TV
    Gray bars while full screen viewing my Broksonic CCVG-4500 42 in
    hi, i have a broksonic model ccv-4500 , these is a monitor or tv because i cant founder the digital cable imput. thanks.
    Apr 25, 2010 | Broksonic CCVG4200 42 in. Plasma TV
    Turn tv on tv goes on for about a minute or two and then the picture goes out but the sound stays on
    COMMON PROBLEM IS LOST CONTACT OF SOME HOT PARTS,POSSIBLE AREA ON POWER SUPPLY ON THE BACK LIGH OR LCD,
    Feb 28, 2010 | Broksonic CCVG-3276 32 in. LCD TV
    I have owned my Broksonic CCVG-3276 since October 2008 and on June 10th, I was able to get sound but the picture went black. When I turn it off for a few minutes then back on, it works for seconds, then...
    Ur LCD inverter backlght board is dead.Replaced this board will get ur picture back.It a long board in shape.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.
    Feb 25, 2010 | Broksonic CCVG-3276 32 in. LCD TV
    My Brocsonic tv has audio and no picture
    its technical work, need to open backcover of tvset' to resolder the heater line section;
    May 12, 2009 | Broksonic TV
    Defective lcd screen
    It's not the screen, it's the inverter that drives the backlight.
    Nov 22, 2008 | Broksonic Televison & Video
    Programing Broksonic TV
    Does it has a built-in Advanced Television Systems Committee (ATSC) tuner?
    May 09, 2008 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
    Broksonic CCVG-3276 32 in. LCD TV Logo
    438 people viewed this question
    Top Broksonic Televison & Video Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
