Question about Lexmark Color JetPrinter Z23 InkJet
My lexmark color jet z23 wont print
My printer wont print, but it will print out the cartridge alignment page
    Sergeant:
  • 276 Answers
Go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the cartridges.as it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Posted on Nov 20, 2008
My lexmark z23 printer keeps leaving blots of ink or marks all over the pages that it prints
You may need to clean the nozzles on your cartridges. Please follow the instructions in this article in the Lexmark website on How to Unblock (Clean) the Cartridge Nozzles in the Lexmark Z13/Z23/Z33 Color Jetprinter.If problem continues, try to insert a different known working cartridge to determine if your other cartridge is faulty. Thanks.
Feb 23, 2011 | Lexmark Color JetPrinter Z23 InkJet
I have installed new drivers and new print cartriges into my Lexmark z23. The test page will print, but when i try to print any other documents, they come out blank??
Good day!Is your new driver compatible with your Lexmark printer?and is your cartridge had no defect?..try to calibrate the cartridge..look to the manual of the printer..
Regards,
mastergani
Mar 21, 2010 | Lexmark Color JetPrinter Z23 InkJet
The alignment both vertical and horizontal are off!
Title: How to Install/Change the Print Cartridge Document ID:HO46 Back To Answers Properties 1000 Color Jetprinter 1100 Color Jetprinter 2030 Color Jetprinter 2050 Color Jetprinter 2070 Color Jetprinter 3000 Color Jetprinter 3200 Color Jetprinter 5000 Color Jetprinter 5700 Color Jetprinter 5770 Photo Jetprinter 7000 Color Jetprinter 7200 Color Jetprinter Lexmark X63 Lexmark X73 Lexmark X83 Lexmark X84 Lexmark X85 Mac OS 8.6 Mac OS 9.x.x WinWriter 100 WinWriter 150c Z11 Color Jetprinter Z12 Color Jetprinter Z22 Color Jetprinter Z25 Color Jetprinter Z31 Color Jetprinter Z32 Color Jetprinter Z34 Color Jetprinter Z35 Color Jetprinter Z42 Color Jetprinter Z45 Color Jetprinter Z45se Color Jetprinter Z51 Color Jetprinter Z52 Color Jetprinter Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How do I align ink jets?
      3. Click OK.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Printer sounds as if it is printing, paper runs through,
Have you tried to clean the nozzles?
Did you print a test page after installing the new cartriddge?
Go there http://www.lexmark.com/publications/pdfs/z33/enuserlx.pdf
Sep 26, 2009 | Lexmark Color JetPrinter Z23 InkJet
Printer wont load paper
To align the color cartridge, simply try taking the cartridge out, and putting it back ini. Most often on Lexmark printers, this will bring up a message asking if your cartridges are new or old and of what number they are. after this menu you will likely be forwarded to a printing alignment page
Oct 04, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark z23 will not print
go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the cartridges.as it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Sep 12, 2008 | Lexmark Color JetPrinter Z23 InkJet
In this model, if the colour does not work then your colour cartridge is either dried up or empty. Try running a few head cleans through your maintenance section and see if it rectifies the problem. If not a new cartridge will fix the problem.
Feb 04, 2008 | Lexmark Color JetPrinter Z23 InkJet
Printer wont print color
plese change the colour cartridge it has dry or finish
Sep 13, 2007 | Lexmark Color JetPrinter Z23 InkJet
Lexmark 710 printer
the ink cartridges may have dried up. try getting one color cartridge to test (color because it can also print black).
Sep 03, 2007 | Lexmark Color JetPrinter Z23 InkJet
Lexmark Color JetPrinter Z23 InkJet Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
