Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Where can we get a wiring diagram for the Motorguide Power PlusT43 motor .
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
  • 553 Answers
SOURCE: motorguide model ht24 looking for wiring diagram to rewire switch
If the insulation is burnt off the main wiring you have a severe short. DO NOT TRY TO USE. Unless your a qualified electrician or motor repair tech, take it to one to have it repaired or by a new one.
Posted on Jun 12, 2010
SOURCE: I need a diagram for the wiring on the pedal of a 756 Brute
Try mike'sreelrepair.com
Posted on Sep 20, 2010
SOURCE: Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Posted on Sep 16, 2011
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
I need motorguide switch diagram
Depending on your actual model, you can find most wiring diagrams here: http://www.mikesreelrepair.com/schematics/thumbnails.php?album=129
The actual wiring is on the last page of each pdf file.
Mar 08, 2014 | Electrical Supplies
I need to turn the propel that is backwards, i bought this electric motor but is bacckwards
Check the motor wiring diagram, you may be able to reverse the rotation. Usually all it takes is switching wire #5 and wire#8 to reverse rotation.
Mar 09, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Only have 5th gear on my trolling motor its a 5 peed but 1 thru 4 do not work already replaced the switch
I have the exact same problem gears 1 through 4 don't work but 5th gear works fine, any help from anybody would be greatly appreciated. There are 4 red wires going into the switch also a yellow and a blue. The 4 red wires all have power going through them in 5th gear but when I switch to the other gears only the two middle wires have power.
Aug 14, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide t47 powerplus trolling motor
t 47 power plus motorguide prop wont turn but you can feel the power going to motor to try to turn it
Jul 06, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide model ht24 looking for wiring diagram to rewire switch
Jun 11, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Can you change a motorguide 65lb thrust foot control model with fix speed settings to a variable speed
well a "Speed Controller" can usually be used on ANY DC/AC motor, depending on type, some motors just will not work, with a speed controller... Think of it a bit like a "Light Dimmer", with the "Bulb" being the "Motor"
Have a look below for info. www.stefanv.com/electronics/escprimer.html
Mar 05, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
