Question about Arris DCT6200 DTV Receiver
Motorola dct 6200/1000 converter box will not power on
Do I need the original power cord for my Motorola dct6200?
there is no transformer in the power cord just straight wall power. the dct 6200 does all its power stuff inside the cable box.... thats why there is no "block" on the power cord.
Sep 14, 2013 | Arris DCT6200 DTV Receiver
Motorola dct 6412 wont turn off
pull the power at the back of the box or the wall, which ever is more convient. then wait for all the power to bleed out of the capacitors takes a minute or two (we call this a power cycle) hopefully it comes back up. might be time to put it to pasture.
Oct 10, 2012 | Arris DCT6200 DTV Receiver
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Hello
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
OK.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
I just want free to air tv from a motorola reciever dct 2224 is it possible
no motorola DCT's can do free to air. The tuner will do it but the controler part of the box cannot
May 25, 2009 | Televison & Video
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
Motorola DCT 2244/1661/abcdeg locked up
Pay Per View events, or IPPV events are stored inside the unit on NVRAM (Non-Volitile RAM) until the DAC-6000 (Digital Access Controller) calls up or "polls" your unit for IPPV events.
THE BAD NEWS:
They cannot be removed by "resetting" the unit.  Some claim unplugging the unit for several hours or days.... other claim that you can unplug the unit, hold down the power and select buttons at the same time, and plug the unit back in (while holding these buttons) and watch the LED screen flash 8888 several times and then let go of the power and select buttons.  All this does is erase the firmware, NOT the IPPV or polling information.
Only the DAC-6000 can remove the events from your unit. Those events are stored in the unit forever until it's correctly polled by the DAC.
THE REALLY BAD NEWS:
Once those events are collected you will be billed for everything you watched.
The "0" you are seeing on the LED screen indicates it has lost it's firmware and is basically a "brick" until it has been properly re-authorized with the firmware and cleared any polling events.
Nov 08, 2007 | Televison & Video
Arris DCT6200 DTV Receiver Logo
263 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
