Question about Brother MFC 420CN All-In-One InkJet Printer
I have a brother MFC-9840cdw printer and it had a "calibration error." We have tried new ink, and replaced the waste toner box, but it still says it is unable to calibrate when you go into that setting. And when you print, the page comes out but it is blank. Any ideas? Thanks!
  • 2 more comments
  • adam408 May 19, 2011
    Thanks for the response but this was the same information that Brother gave me, and ive tried it several times. Ive looked for debris etc but it still will not calibrate. Any other ideas?
    i have the user manual with me and it provides no useful tips on this problem. So, in summary, the suggestion is to either find a solution in the user manual, or replace each of the waste toner box, drum and belt and see if it then works?
    Brigadier General:
  • 3,917 Answers
Hi
Please download this link for the user manual to get the calibration error fixed:-
http://www.retrevo.com/support/Brother-MFC-9840CDW-Multifunction-Printers-manual/id/3258dj787/t/2/
Also if the calibration fails then check this link bellow:-
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000076/faq002676_001.html?reg=us&c=us&lang=en&prod=mfc9560cdw_us
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 19, 2011
  • 656 Answers
1. Power off the Brother machine.
2. Inspect the belt unit.
a. Press the front cover release button and then open the front cover.
b. Hold the green handle of the drum unit. Lift the drum unit up and then pull it out until it stops.
c. Remove the drum unit. Make sure that the gray lock lever is in the up position.
d. Hold the green parts of the belt unit with both hands and lift the belt unit up, then pull it out.
e. Rotate the gear on the belt unit and inspect the belt for foreign material paper, toner etc. Remove any foreign material and clean off any toner with a soft dry cloth.
f. Look inside the machine to look for any scrap piece of paper, especially towards the back. If you find scrap piece of paper remove the paper.
g. Put the belt unit back in the machine. Match the down arrow mark on the belt unit to the down arrow mark on the machine. Push down on the green area of the belt unit to lock it in place.
h. Put the drum unit back in the machine as by making sure that the gray lock lever (1) is in the up position and put the drum unit in the machine. After the drum unit is in the machine push down the gray lock lever (1).
i. Slide the drum unit back in the machine.
j. Close the front cover.
k. Power on the machine and allow the machine to go to normal ready mode.
3. Color calibration:
a. Press the MENU key.
b. Press the DOWN ARROW key and scroll to "Printer".
c. Press the OK key.
d. Press the DOWN ARROW key and scroll to "Calibration".
e. Press the OK key twice then 1 key.
f. The LCD will display "Please Wait".
The Brother machine will start to calibrate and when calibration is complete, the machine will return to normal ready mode.
Posted on May 18, 2011
Ive replaced the waste toner box in a Brother MFC-9140CDN but the replace WTB message still continues and I still can't print. Its supposed to last for 50,000 pages, its done 8,000 pages.
Check your operator''s manual for a reset procedure. If this doesn't work, pull the AC plug overnight, if the error isn't stored in a flash memory, this may help reset it.
Jun 25, 2015 | Brother Office Equipment & Supplies
What is no waste toner on mfc-9840cdw
The 9840 uses a WT100CL cartridge for collection of Waste Toner.
If you remove the Drum Unit then the Plastic Sheet (Transfer Belt) like thing the Waste Toner sits underneath this. Lift out the waste toner and replace it or put one in if it is missing.
Put the Transfer Belt and Drum Unit back in. Close the machine and away it goes again.
Oct 01, 2014 | Brother MFC-9840CDW Laser Printer
Brother mfc-9840CDW waste toner box replaced but error message continues
Waste toner box doesn't require resetting and cannot be reused.
Try to take it out and install again.
May 13, 2014 | Brother DCP 115C All-In-One InkJet Printer
Waste toner box in mfc9840cdw is full
The waste is captured more for easy, clean and safe disposal. As far as operation ogre the printer you could empty the waste and RE use the bottle.
Jan 12, 2013 | Brother MFC-9840CDW Laser Printer
Waste toner full MFC 9840
I followed the instruction here to enpty the toner box (http://www.howtofixcomputers.com/forums/printers/brother-mfc-9440cn-waste-toner-box-reuse-288524.html) and I am no surgeon or even mechanically inclined, but it was very easy to do and worked without any problems!
Jan 08, 2011 | Brother MFC-9840CDW Laser Printer
How do I reset the waste toner box in my MFC-9840 Brother printer? (without purchasing a new one)
1. 2. -> unscrew
shake to empty
http://s14.directupload.net/images/130409/awjs9m88.jpg
Jan 07, 2010 | Brother MFC-9840CDW Laser Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
383 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
