Question about Cycling
To connect alarm system to bike - Cycling
  • 10,865 Answers
Hello kay. go to your local bike shop and have the clerk show u the variety of alaarm systems available. Also invest in a high end bike lock, remove the front tire and even the seat if they are on quick release locking mechanisms. Joe
Posted on May 18, 2011
2005 FXSTB alarm system key icon lite on speedo, left blinker not working, bulbs good, bike starts and runs normal alarm system able to activate right side blinkers only flash
Hi Brian, you may have a faulty turn signal module or faulty connection or you may need an alarm reset, for more information about your question please visit the website below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Aug 21, 2013 | 2000 Harley Davidson FXSTB Night Train
I have installed a cyclone alarm on my bike but now my indicators dont work unless I'm arming the alarm and my dials dont work but do light up :'( my bike is a gsxr 600 srad 2000 model
Sounds to me like you have made an error somehere, the indicators are not meant to be cut only just cut back the insolation and solder the alarm indicator wires onto the left and right indicators, best to the rear, DONOT CONNECT AT FLASHER RELAY,
Recheck your connections, only cut the system you wish to protect ie imobiliser alarm, follow the instructions carefully if
you have any, slightly grey area, with security devices as the information in the wrong hands could have bad concequences
Sep 08, 2011 | Suzuki GSX-R 600 Motorcycles
Hi there! I want to remove my alarm system from my bike. It is a MetaSystems Defcom3 alarm. Although I managed to disconnect all connections of the alarm from the bike, when I try to ignite, the bike...
Are you connecting like color codes to like? Wires that were cut in order to install the alarm need to go back together as they were originally. It sounds like you're doing the right thing but you might want to double check the color codes to make sure you din't mistake one for another.
Jun 27, 2011 | Suzuki GSX-R 600 Motorcycles
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
Harley alarm system wont let me start my bike
Hi P_o_box55, for more information on your question please visit the websites below and good luck:
Harley Diagnostic Codes 04 to Present
Apr 27, 2010 | Harley Davidson FLHR - FLHRCI Road king...
How to put bike into service mode to carry out work.
Hi Lincolnboy, for more information about your question please visit the websites below. Good luck and have nice day.
Apr 23, 2010 | 2005 Harley Davidson FLSTC - FLSTCI...
Yam r1 no go,put new batts in remotes,meta 357t,will not code in,can not turn imobb off to start bike up.(help)
got bike started,managed to recode remote just once,when bike stopped, would not restart alarm has spiked back,requires new alarm system.
Feb 15, 2010 | 2001 Yamaha YZF-R1
I have a triumph tt600 with a datatool veto evo alarm on it..yesterday i went to unset the alarm and found it would not unset so i changed battery in the alarm fob but still no joy the lights on the alarm...
Ok i see, Have you checked the bike battery? is it charged or has the alarm worn it down? One thing about bike alarms is that they constantly drain power from the bike battery when the alarm is armed on not. If you ride your bike every days no problems , if you ride on week ends only you could find yourself in this predicament again so, on the alarm wiring you should be able to locate the power supply to it from your bike battery, this wire will have a fuse in it so check the fuse too , and if you want to keep it off because your done with alarms, then just leave the fuse out and you should be back in business. If your bike won't start because the alarm has an immobilizer , to remove it would be easy if you know where it is connected to, in your case the ignition which, there should be evidence of where they connected it and it will require you to remove your tank and seat for access so be prepared to get the tools out , the immobilizer is usually connected directly to either the harness or the ignition switch, unfortunately to find the connection point will be difficult because each alarm installer hides his wires differently so , your gonna have fun locating them, your best bet is to check your bike battery , should be 12 volts or better if it reads 10 or 11 volts or less , get a new bike battery to get the bike going and take it to your local triumph store, the mechanics there no those bikes inside out ,   The alarms we have here do the same thing , i also have a triumph , (rocket 111) i have had the pleasure of riding the TT600 , a very fun bike to ride, the way i see it , if they can steel it and they can't find it , my insurance will get a call, I've had alarms in the past and believe me their more trouble than their worth,
I hope i helped and not driven you crazy, lol ride safe :)
May 17, 2009 | 2001 Triumph TT 600
2003 Dyna FXWG low battery?
sounds like the alarm is set and wont let the ignition work
Mar 19, 2009 | 2003 Harley Davidson FXDWG Dyna Wide Glide
Cycling Logo
29 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
