Question about Dishwashers
It seems like dirt in glasses and cups in the topack of the dishwasher, is there a kind of filter that should be cleaned??
  • 4,323 Answers
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Daniel
Posted on May 19, 2011
Sand on inside of cups and glasses on top rack of dishwasher
it souds to me like lime scale detaching its self from the heater element.
try calgon, it should fix it
Jun 03, 2012 | GE 24 in. Profile PDW7880G Built-in...
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
Cups and glasses are not clean technician can not find a solution
Hi pamkilg,
I hope this will help, please check my Tip below:
DISHWASHER NOT CLEANING PROPERLY...
Kind Regards :-)
* If you found this solution helpful, please rate it
Jul 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
What causes the pungent odor in dishwasher? It seems that the all the water are not being dried
Hi, this is a very common problem and can be sorted out easily, rather than explain it here i include some weblinks that explain it all in detail. plus my favorite below.
http://www.ehow.com/how_2330730_remove-odor-from-dishwasher-.html
http://www.mrscleanusa.com/en/cleaning-tips/kitchen/clean-dishwasher.html
Here is one that takes the smells, hard water stains etc out of your dishwasher and plastic and glass ware. Fill up dishwasher, with plastic glasses, glass ware, dishware. No metal, of any kind! anything you want sparkly and clean.
No detergent! Fill up a small bowl at the Bottom of the dishwasher with vinegar, 1 cup of white. Run the cycle, do not dry. Fill up with 1 cup of bleach, run again. This takes care of all hard water stains, germs that are causing smell etc. Also check for food at the bottom of the dishwasher.
The site below explains WHY you get those smells.
http://www.doityourself.com/stry/what-causes-dishwasher-odor
Aug 19, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
Leaves residue in cups
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 21, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dishes are not getting clean
Hi there.
In the bottom of the dishwashers is normally a filter with a handle on it for easy removal. pull it up, gently, you might have to turn it slightly from side to side to loosen it if it is very dirty. When this filter is out you will see another filter that is just lifted straight up and on that one you might find a lot of dirt.Put both filters in a 10 liter bucket with on cup of chlorine(diluted to 5%) to 5 liters of water. Pour some chlorine( 2 cups) into the bottom of the machine, and close the door and let the machine run on its hottest cycle until finished. When the machine is finished, rinse out the filters in the bucket with warm water. Brush the rest of the dirt off and replace them where they were. Run the machine once again, now on a normal cycle with the dishes in it and I believe they will be clean.
Iceman.
Nov 04, 2009 | Maytag MDB7100AWB Dishwasher
The dirt that comes off the dishes does not wash away
Is the filter screen over the drain at the bottom of the dishwasher clogged? Maybe the drain hose is kinked or clogged. If not, check the fitting where the hose connects to see if it maybe clogged. Please rate this advice. Thanks!
Aug 21, 2009 | Dishwashers
Kenmore 665 15899 dishwasher won't clean
Make sure the filter inside the dishwasher is cleaned out and read about my advice for dishwashers for more tips.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Jan 31, 2009 | Kenmore 15899 Built-in Dishwasher
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
