Question about Canon PIXMA MP600 all-In-One InkJet Printer
Error E5010 and B200 in the pixma mp600,simultaniously,I have already changed the new printer head and goes on the same problem,could be the logic board??.nowadays i´ve got a lot of new cartridge and a new print head. thanks.
  • 310 Answers
SOURCE: Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
Posted on Mar 03, 2008
marked
  • 6487 Answers
SOURCE: I`ve got a canon pixma
You need to uninstall the software for you printer and , try to reinstall it again make sure you're using the software that is made for Vista and that should fix it...
Hope that helps.......
Posted on Sep 15, 2008
puertobori
  • 7733 Answers
SOURCE: error code E5010 on Canon Pixma MP510 in LCD
Try Canon U.S.A. : Support & Drivers : Consumer & Home Office
Posted on Oct 20, 2010
duane_wong
  • 6826 Answers
SOURCE: Canon Printer Pixma MP540 with
Try to press down on the sponge to get it to work again. It may be a waste toner issue, which generally is repaired at an authorized service center for canon by contacting 1-800-OK CANON or logging on to canonusa.com.
Good luck on this.
Posted on Feb 12, 2011
What does erro code b200 mean
Error B200: A service error has occurred.
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, the device needs to be send to service for repair.
It can be that only the print head has malfunctions, but mostly it is another defect in the printer which causes also a defective print head. Changing the print head can solve the issue for a couple of weeks, but then the error will occur again.
May 17, 2014 | Canon PIXMA MP600 all-In-One InkJet...
Error b200 in cannon pixma 258, how to fix
VH monitor error or Error Code B200
Condition: The print head voltage is abnormal.
Problems and Solutions:
  • Replace Print head and logic board (Replace them at the same time.)
  • Replace Power supply unit
  • Check and Clean Head contact pin condition of the carriage unit
  • Check Cable connection especially the carriage FFC
Regards
Sep 26, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to solve error b200 reply me easy and clear way.Please help me.reply me hurry
The print head has a voltage fault. This is usually caused by the logic board going faulty and sending too much voltage to the print head. You will need a new print head and main logic board. This would probably cost more than the machine is worth. Buy a new printer.
Aug 26, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Canon pixma pro9500 mk2. error code b200. printhead problems. cannot access printhead, because it is locked in resting position due to error code. how do i get it to the middle? thanks!
PIXMA Pro 9500 MKII Error B200 = VH (Print Head Drive Voltage) is out of the specified value.
Need to :
- Replace print head and logic board at the same time.
or
- Replace Carriage Unit
or
- Power Supply Unit
Aug 17, 2011 | Canon PIXMA Pro 9500 InkJet Photo Printer
I have canon MP510 printer 4 years old not over used. Was ok earlier in the day, now green and yellow lights flashing and paper feed light not lit. shows B200 error message. should I just buy a new...
The error B200 is an internal overheat error. It is usually associated with an overheating print head. The fault can be with the print head,carriage or even the logic board. You will not be able to locate the trouble unless those 3 items are replaced in that sequence. in other words SCRAP it as the costs will be enormous.
srri
Aug 09, 2011 | Canon PIXMA MP510 All-In-One InkJet...
WHAT IS THE PROBLEM WHEN APPEARS ERROR B200?
The error B200 refers to an overheat error of the printhead. however the head usually damages the logic board and both require replacing as a pair. Sorry but probably not an economical repair and a replacement machine is better.
Jun 19, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Canon pixma MP600 error code 5010
My Printer is coming up wiht a printer error B200, and i dont know what to do about it.
Jan 15, 2011 | Canon PIXMA MP600 all-In-One InkJet...
MP600 power goes off after a few seconds. Printer won't print. Got B200 error code at one time.
Hi there
It may be the cartridge...try removing it and then reseating it. If that doesn't do it, clean the contacts with water or isopropyl alcohol.(power off when you do this)
If that not work then you need to change the ink
All the best Pineworks
Mar 01, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
131 people viewed this question
old marine
old marine
