Question about Vacuums
Have Model HFQ15A but lost directions. Need to know what the two dials on top of fa n/heater are all about and how to best use this product. Thanks for your help.
Lost manual need to know how to use as a wet vac 2 hp model Qas60
Here is a list of MOST Shop Vac Manuals. I did not see your model number, however you may be able to find it know the exact name of the vac. Best of luck!
http://homeappliance.manualsonline.com/manuals/mfg/shop_vac/shop_vac_vacuum_cleaner_product_list.html
Mar 10, 2011 | Vacuums
Vac light comes on after i changed the bag
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
http://evacuumstore.com/
Apr 14, 2010 | Electrolux Lux 5500 Canister Vacuum
Electrolux Epic 6500 Vacuum - Suction stops when hose is attached
You can ship the vacuum to http://evacuumstore.com/ and they can reapir it for you.
Mar 28, 2010 | Electrolux Epic 6500 Vacuum
HELP!!dyson vacuum only 2 years old model DC18 runs but has lost suction on the wand side of the vacuum does anyone have any suggestions for us??
its the ball cradle assembly. There is a little clip that changes the direction of the suction. that clip breaks all the time and causes the internal direction valve to stay in one position. unfortunately dyson doesnt sell these parts separate, you will have to purchase a new cradle assy. let me know if you need a part #
Jan 06, 2010 | Dyson Vacuums
Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Sep 28, 2009 | Electrolux Vacuums
I have lost the directions to replace the belt. Can you e-mail me the directions?
If there are no screws on the bottom part/sole plate where the roller brush is, then check the top of the hood - there should be three screws, two at the front on the raised section of the floor brush top and one below the hose if it sits to the left hand side of the machine at the bottom. Undoing them and possibly taking off the rotary dial height control should give you access to the drive belt. Be careful with the seats of the roller brush (what the brush sits in) as these are notorious for falling out and are poorly directioned as to what position they should be in.
Jan 19, 2009 | Eureka Capture Upright Vacuum Vacuum
Electrolux 2000 Mod# c151c
Turn the knob on top all the way to the right
Jul 04, 2008 | Electrolux UltraLux 2000 Bagged Canister...
I need to replace the belt on my vaccum. I lost my manual.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698951
Generic problem for all Vacuums
Posted by 4eversofia on Jun 23, 2008
I need to replace the belt on my vacuum. I lost my manual.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to change your belt I would need to know the brand name and the model # in order to give you the correct information to change your belt, so a little bit more information needed as to what you have and then I can direct you in the belt change. Normally there are screws in the bottom of the vacuum and once you remove the screws or clips you can either change it from the bottom or the top cover will lift off and then you can get @ the belt from the top.The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
The dial regulating suction does not seam to work the vacuum works constantly on the full power and the light indicating overheating stays on.
This would depend on the brand and model number you have – without knowing the model or brand of vacuum you have it would be hard to give an accurate answer – the over heating light could indicate some type of clog or blockage and may have nothing to do with the dial to regulate the suction – that merely is a height adjustment …. As this does happen to most vacuums that the overheating light comes on – if there is no problem have it looked at from your local vacuum dealer or repair shop would be the best advice that I could give you.
Apr 15, 2008 | Vacuums
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
