Question about Brother IntelliFAX 2800 Laser Fax
What is replace drum soon?
I keep getting this message replace drum soon on my LASER plain paper fax and copier, Panasonic KX FL511.
  • Anonymous Mar 19, 2014
    Says replace parts drum,of unit1,fluster and laser unit.. Won't let me print
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
How can I reset Replace Drum on the Panasonic KX-FL511 Fax?
First of you will have to purcahse a Panasonic Drum Unit for you fax.
Inside the drum unit yu will have detailed instructions, you will open up the fax in the front take aout the old and install the new.
Here is a link to a helpful guild
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/How-To-Guides/model.KX-FL511.H#ts
Good luck
Nov 05, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Need user manual
You can download a manual here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/model.KX-FL511
Feb 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
"DRUM LIFE OVER" KX-FL511
just change with new drum and toner.after replacing when msg gone just press start.u will receive ur faxes in memory.MIAN AKHLAQ
Dec 31, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Keep Adding Toner to Panasonic KX-FL511
kindly follow this instruction
but doing this will erase all the message in the memory
press menu #9000*550 start
unplug the unit once heard the beep
after 10 seconds, plug it again
Jan 28, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
DRUM REPLACEMENT CODE
How to Reset the “Replace Drum Cartridge Soon” Message on a Panasonic KX-FL511
[Menu]
[9000]
[*] (Will display P-SF)
[6722]
[Fax Start]
[Menu]
Nov 18, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Error
clean the drum unit by opeing it and cleaning the wiper blades etc. In case it does not help please replace the drum unit Happy faxing Omipresent
May 11, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
