Question about Sony XPLOD CDX-GT200 CD Player
I have a Sony CDX GT200, it won't switch on, I have cheched the red 10A fuse at the back and its O.K, there IS power going to the red wire also, and there is no fuse faults in the main car fusebox, I press disc eject and the disc comes out, it also loads the disc but wont play or switch on, I have tried the reset button behind the faceplate and also pressing source afterwards, none of this seems to work, pressing reset without a disc in i hear i drive motor resetting but with a disc the unit is silent, even after resetting the reset button i re-attach the faceplate and it still won't work i do not have the remote, any ideas??
  • 323 Answers
SOURCE: Need faceplate for Sony CDX GT310/GT31W auto unit
I spoke with a representative from Sony and this is what they told me.
In order to help you place an order at the earliest, I would suggest that you contact Direct Accessories and Parts Center (DAPC) at 1-800-488-7669.
The hours of operation are as follows: • 7:00 am to 9:00 pm Monday through Friday, Central Time. • 8:00 am to 6:00 pm on Saturdays, Central Time. • 11:00 am to 5:00 pm on Sundays, Central Time.
Posted on Feb 09, 2009
  • 94 Answers
SOURCE: wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Posted on Mar 08, 2009
SOURCE: CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
Posted on Jul 11, 2009
  • 10 Answers
SOURCE: need wiring diagram for sony cdx-gt200
blue\white stripped= amp remote
black= ground
blue= ant
red=positive
yelow=positive 12v
white=left +
white\black striped= left -
gray= right +
gray\black striped= right -
green=left rear +
green\black striped=left right -
purple=leftr rear +
purple\black striped=right rear -
Posted on Jul 19, 2009
jyackle5
  • 8197 Answers
SOURCE: need wiring digram for sony xplod cdx-gt200
Go to link below for manual on page 22 has wiring diagram.
http://akamaipix.crutchfield.com/Manuals/158/158GT200.PDF
Posted on Nov 22, 2009
I need a replacement remote for my Sony cdx-gt200
If you are in the U.S. you can order one at pacparts.com. The part number is
1-479-077-17.
Nov 04, 2012 | Sony CDX-GT200 CD Player
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
Aug 28, 2012 | Sony XPLOD CDX-GT200 CD Player
Hello, umm my CDX-GT200 sony player in my jeep as been working great.. however just the other day I was driving home with it playing the radio and all of a sudden it just powered off.. and now when I try...
hi firstly check your fuses ,remove the player from dash check all wirering especially the positive + and - negative ,should be black and red ,check with multimetre for current at these wires you can disconnect the power block from the radio if you like and check for power this way .hope this helps you goodluck
Mar 18, 2011 | Sony XPLOD CDX-GT200 CD Player
I have a Sony xplod in dash am/fm/cd player with the flip down front where it does not allow me to play the radio or cd's. the car fuse is fine, is there another in-line fuse or is the player dead?
the back of the unit has a 10A fuse pull out the stereo and check that it takes a normal car fuse if u have a spare 10A fuse replace it if it is blown
Nov 04, 2010 | Sony XPLOD CDX-GT200 CD Player
My sony explod cd for my car wont power on everything is hooked up and it will eject the cds but nothing else..what do i do?
check the radio fuse on your car most likely its bad. If you pull out the radio the red wire should have power when the key is turned on and if not you have a fuse problem
Jun 14, 2010 | Sony XPLOD CDX-GT200 CD Player
Sony CDX GT200 does not work... is there a fuse in this radio? I cannot turn on the unit now. I just got my car back from the repair shop and they replaced my battery and alternator, but now my radio...
There is a fuse in the back of the stereo unit. Also trace the red wire from the stereo to where it's connected, and check the fuse for the circuit that the stereo is connected to.
May 22, 2010 | Sony XPLOD CDX-GT200 CD Player
My ignition barrel broke for my vauxhall corsa,been fixed but my sony gt200 cd/radio will not come on . will not play.usually when you clip the front face unit into place the system lights up.at the moment...
your cd switch wire is not recieving any power. when you turn on your key it turns on the switch wire. the wire/contact on the ignition barrel may not have been connected properly. check the wiring and the barrel again
if this doesn't work connect the yellow and red wire at the back of the radio.it will work without the keys now
Sep 23, 2009 | Sony XPLOD CDX-GT200 CD Player
Sony CDX-GT200 wiring query
The ariel switch is for a power antenna to make it rise when you turn your stereo on. The orange wire is for your dimmer when you turn on your car lights. You do not need to hook either of these up.
Aug 09, 2009 | Car Audio & Video
Wiring color meaning
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
Sony cdx-gt200 no power
its knackered either send it in for repair or buy another amp at wholesale cost here:
www.godspeedaudioheaven.com
Dec 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony XPLOD CDX-GT200 CD Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
