Question about Garmin nuvi 255W GPS Receiver
How to connect my garmin nuvi 255w to a computer
  • 343 Answers
To connect the Garmin 255w you will need a usb cable. If you don't have one that came with it you can check all your other electronic devices like camera, camcorder,mp3 player etc..( my mp3 player usb cable worked fine). Carefully and gently try each one. One you get a usb cable connect it directly to a usb port on your computer and not thru a usb hub. then go over to the Garmin site and register the unit and download Garmin updater to update your unit. I am attaching the Garmin link for you. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
Posted on May 19, 2011
Rebooting my garmin thru the computer
Rebooting the Garmin Nuvi 255W is done when disconnected to external sources of power or connection to the computer.
The computer connection is used to transfer map data and software updates to the GPS.
The software updates are done using the Garmin WebUpdater program.
Jan 15, 2012 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
Need to update my gamin nuvi 255w online where do i go?
Details on how to update your garmin nuvi maps are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
To update your software only connect your satnav to your computer. Download and install webupdater on your computer from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
When you run the program it will update your software.
Oct 01, 2010 | Garmin nuvi 255W GPS Receiver
WHEN I POWER ON MY NUVI 255W IT SAYS NO DETAILED
sounds like the map folder in the gps software got corrupted. you will have to connect your device to your computer, get on the Garmin website, and let the garmin site update your device. Once updated, it will re-install the correct folders and maps to their proper place. the gps should work as before after that.
Mar 30, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Garmin Nuvi 255W Favorites Backup and Restoration Procedure Models: Garmin...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Garmin Nuvi 255W Hard Reset Here.
Garmin 255W WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Garmin Nuvi 255W Favorites Backup here.
Can i charge my garmin 255w thru my laptop
Yes you can,Connect your nuvi to a computer using a USB cable.The computer must be on for the nuvi to charge.A camera USB cable can be used to do this,or any USB cable that fits both the nuvi and USB port on the computer.
Jul 15, 2009 | Garmin nuvi 255W GPS Receiver
Garmin GPS 255w Nuvi system files missing
Call customer service 1-800-800-1020
They were able to fix my 255W by linking to it through my computer.
Jan 18, 2009 | Garmin nuvi 255W GPS Receiver
Tip
Download Nuvi 255W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
644 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
