Nokia 5200 Cellular Phone Logo
Anonymous Posted on Aug 14, 2008
My nokia 5200
Dose it have to b turnd on or off Comment by bretts_polo, posted on Aug 13, 2008 i also took the back part off and dryed that would it b owt in there Comment by bretts_polo, posted on Aug 13, 2008 and aloso is there any coads on the bk of the phone under the battery i can use to unlock it on any network i.e o2 or blk
  • 1 more comment
  • Anonymous Aug 16, 2008
    a realy need the screen to show me a picture the background light is lightin up but no picture ive tryed leaveing it on charge for 3 days but no luck can u help me??
  • Anonymous Sep 09, 2008
    hi there my nokia 5200 is on tesco mobile and i need it unlockin my ime num is354565/01/920006/60546129 thanks brett
  • Anonymous Nov 10, 2008
    phone locked to Tesco Ireland
Anonymous
Level 3:
Brigadier General:
  • Master 7,752 Answers
  • Posted on Aug 16, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
7752
Questions
Helped
1415333
Points
13016
You can try online at www.lockitnow.com or www.mobile2mobile.net or take the phone to a mobile shop and have them unlock it for a small fee usually in 24hrs are less.
De Dietrich Quattro dishwasher keeps showing d06 error message why?
Fixya had one suggestion a number of years ago:
Quoting:
Jamie Nye
I took Brett's advice and went straight to the run capacitor, this was in a DeDietrich, showing d06 fault. Machine is fixed and running within 48 hours without leaving the kitchen, thanks Brett.
Posted on Aug 20, 2016
http://www.fixya.com/support/t12442822-de_dietrich_d06
Quoting from a Dietrich dishwasher manual:
"high pump flow fault"
https://cdn.shopify.com/s/files/1/1599/8433/files/DETRICH_DVH1150J.pdf
1helpful
Nokia 5300
try this
http://www.meramobi.info/2010/08/only-70-sets-allowed-problem-solved.html
if you have any problem regarding this post comment on meramobi.info site they will help
hit thanks if u like
1helpful
Hi My 5200 dose not see my sim? any ideas
try removing battery pack, un-clipping sim lockdown, removing sim and cleaning contacts with q-tip just damp with rubbing alcohol, also clean contacts in phone, where sim seats. let dry a few minutes- keep fingers off of contacts when you replace sim card! lock it down securely- probably hear a 'click'- replace battery- try using phone again- if this doesn't work- you may have a defective, or non-activated sim card.
either way, contact nokia and tell them your problem.
good luck!
9helpful
Nokia 5200 screen
yes but you should take the phone in and have it check adn the LCD replaced.
Gettin myscreen to hav a pic on it
the LCD need to be replaced so take the phone to a mobile service center and have it done.
What do I ask you that I already have not asked ?
I don't know what do you want or what you are asking but incase you are unable to see my full solution which I posted into your premium, here it is again. Solution #3 posted on Aug 09, 2008 0%20stars_w.png
Ekse
Rank:guru_s.gif Guru
Rating: 85%, 1186 votes
Looking for other codes, but while im doing that you can try
COde search function is an alternative method to programming your device without using the code list
Turn on the device you want to set
Aim the remote control at the device
Press the decive button for the item you want to program
Press and hold the SET button until the LED light up solid red
Press the MUTE/SEARCH button. The LED will shut off first then light up solid red.
When the device turns off, press the OK button to store this code.
Comment by Ekse, posted on Aug 09, 2008 you can try 030, 041, 061, 106, Comment by Ekse, posted on Aug 09, 2008 A few more:
003, 004, 005, 006, 008, 029, 111, 112 Comment by Ekse, posted on Aug 09, 2008 More: 170
Unlocked nokia 5200
IMEI - 352731015226537
Security Code - 1006563355
40helpful
7answers
How to unlock nokia 5200 security code
i forgot my security code.
nokia 5200
IMEI 356407/01/387675/70534428
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
