If your Pol wheel sometimes stops turning and you could force it half a turn to make it go again. Chances are that you have the same problem as mine: HAIR GETS AROUND THE AXIL OF THE DRIVE WHEEL.
This can be fixed by first removing the wheel cap with a flat head screwdriver, then remove the retaining clip that holds the wheel in place. (Be careful not to lose the clip!). Remove the wheel and remove the hair around the axil. Put things back in reverse order. You are set.
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
I may have a machine you can use for parts. I have a BB380 which mixes the dough OK but trips the electrical core balance switch in the house when it goes to bake - so I was taking the pan out and bakeing it in the gas oven. But I got tired of resetting all the electric clocks in the house and bought a new machine. Would this be of assistance?
