Question about Canon PIXMA MP150 All-In-One InkJet Printer
Have changed black ink cartridge on MP150 printer and now printer will not print.
    Genius:
  • 1,127 Answers
Hi
Please check your fix the cartridge properly, remove the cartridge and fix again, and checked any paper jam is there, remove that one also...
Posted on May 18, 2011
Black ink cartridge is full, when printing no black showing
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
Start with printer on then run this software
Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Or
When you insert a refilled ink cartridge into your Pixma MP500 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won't get the warnings again because the ink levels won't be monitored by the printer.
Feb 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I want to use only the black ink cartridge. How do I change the printer from using color ink cartridge to black only? Right now, it is set to use color ink only and when I depress the "Black" button, it...
Check the Canon control panel that came with the printer (they are not the same from one model to the next) and check for a setting for 'Gray scale.' If you are printing only text, it should default to the black cartridge.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Black is not printing, I changed black ink cartridge, and I performed print head cleaning at least 6times still no luck. What causes black not to print?
Please check if the cartridge has been seated correctly. When you replace it it there should be a little click sound which confirms that it has seated properly.
Also, I hope you removed the thin cellphone covering from the ink pad. It is there to prevent drying up when the cartridge is packed for long storage. Check
If it still does not work then the print head is damaged which you have to replace it.
Jun 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How ro avoid color cartridge while it is unrecognized because i wanna print using black ink only
Most printers firmware from the manufacturers have hard coded the commands into the firmwares program to see that the color and the black ink cartridges are inserted before the printing process can begin. Electronically the voltage check sums will not be correct until both ink cartridges are inserted thereby giving an error or not enabling the print process.
Apr 13, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have a full black ink cartridge and no color cartridge and it won't print - black and white text.
In the Printer properties
There is an option like:
Print in color Print in Black and white (it may be different wording for different printers)
Change it to print in B&W
When you get your color cartridge remember to change it back to color - Normally it should be left in color.
hope this will work for you
luciana44
Dec 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP150 consumes color ink when ''Ink Cartidge'' = ''Black Only''
In order to keep the printhead free of clogs, all inkjet printers 'clean' the cartridges (color & black) fairly often. In my experience, a printer that is used regularly doesn't need 'cleaning' as often as it is done since this is an ink-wasting procedure and one that keeps the orders coming in for new cartridges where the vast majority of the profit is. Printers used only infrequently do have a tendency to clog and produce the poor quality we all hate.
Epson printers have ceramic printheads (the models I know) which will last just about forever providing they are used regularly. In home use, they have an ugly tendency to clog and often cannot be restored to their otherwise excellent performance. Printers using the integrated printhead/cartridge are easier to keep printing but this system makes the replacement cost much higher and the manufacturing cost slightly higher.
While HP hardware and consumables were made in the US (outside San Diego), I knew employees there and the early integrated cartridges cost a whole ~ 85 cents to produce and $20-$30 dollars to buy at retail.
Printing quality has unquestionably improved but it isn't likely to get any cheaper.
Dec 02, 2009 | Canon Office Equipment & Supplies
Want to set to use Black Ink only how do I turn colour off
Go to Printers and faxes -> select your printer Canon MP150, right click -> properties -> maintenance -> ink cartridge settings -> select the ink cartridge for printing -> select Black only
Remember printer need both cartridges inside it for initialized and print.You can't print only with black cartridge in printer.
Nov 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
No print on Canon Pixma MP150
it is problem your printer black cartridge .Black cartridge is signal E 5 color cartridge is E6.please change it you buy a new original cartridge
black ink cartridge chip is demage
Jul 20, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printing wrong colors !!!
Post a New problem for Canon PIXMA MP150 All-In-One InkJet
Oct 31, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
