Question about Microsoft Xbox 360 Console
I have an xbox 360 and turned it on and it said i had no internal memory. I tried using an usb storage device and the xbox didnt recognize it?? How would i go about trying to figure out how to fix it?
  • 20 Answers
Well, you have two options, but your main problem is most likely that your CPU is over-heating. You could fix it yourself, BUT, this can be risky, time consuming, and complicated, i would recommend contacting Xbox costumer services and seeing what your options are with them, if you want instructions on how to fix it yourself, try searching it on google ("how to stop Xbox 360 CPU from overheating").
Posted on May 18, 2011
Error 40a3-0000-3080-0502-8007-045d
I got this from the Xbox support site for your error code.
Error Code xxxx-xxxx-xxxx-xxxx-8007-045D
A storage device (such as a memory unit or hard drive) was not found during the software update. Follow these steps:
  1. Turn off your console.
  2. Remove all console storage devices, including any USB flash drives, external hard drives or the internal hard drive on the Xbox 360 E console or Xbox 360 S console. Learn how to remove the hard drive.
  3. Add your primary storage device, for example, the hard drive.
  4. Turn on the console
  5. Try updating the console again.
Here's the website if you wish to peruse it further.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Post back how it works out!
Jan 06, 2014 | Microsoft Xbox 360 Console
There is something wrong with my microsft account its not letting me log in and the code is 8015d003
You see the following error message when you try to sign in to Xbox Live:
Sorry, something's wrong with your Microsoft account. Go to https://account.live.com for help.
Status code 8015D003
This may mean that there's a problem with your Xbox profile.
Solutions
To resolve this issue, try the following solutions.
Solution 1: Verify your Microsoft account security information
  1. Go to Microsoft account. If you forgot your password or it doesn't work, reset your password.)
  2. Click Edit security info.
  3. Verify your security information. For example, verify the Phone number, Alternate email address, and Security question information.
  4. Sign out of your Microsoft account, and then sign in again.
  5. Try to sign in to Xbox Live again.
Solution 2: Clear the system cache
  1. Press the Guide button on your controller.
  2. Go to settings and select System Settings.
  3. Select Storage or Memory.
  4. Highlight any storage device, and then press Y on your controller. (It doesn't matter which storage device you select; the cache will be cleared for all storage devices.)
  5. Select Clear System Cache.
    Note Repeat this step three times.
  6. When you are prompted to confirm storage device maintenance, select Yes.
  7. Repeat steps 4-6 three times to fully clear the cache.
Solution 3: Move and then redownload your Xbox Live profile
Note If you want to use a USB flash drive or a USB hard drive to complete these steps, you must format the USB flash drive or USB hard drive for Xbox storage. (See USB flash drive support for Xbox 360.)
  1. Move your profile to a USB flash drive or USB hard drive. To do this, follow these steps:
    1. Plug the USB drive into your console.
    2. From the Dashboard, go to settings and select Storage.
    3. Select All Devices.
    4. Select Profiles, and then select your gamer profile.
    5. Select Move.
    6. Select the Memory Unit that you want to move your profile to.
      Note A Memory Unit can be a USB flash drive, a USB hard drive, or the Xbox 360 Hard Drive. Be sure that you move the profile to a USB flash drive or a USB hard drive.
    7. Remove the Memory Unit from your console.
  2. Redownload your profile. For details, see Download, move, or delete your Xbox Live profile.
Sep 27, 2013 | Thorogood Boots 534-6333 Womens Code 3...
How do i transfer my avertar and saved game data onto a usb stick on a xbox360
Ensure your Xbox 360 is equipped to handle your new USB driver. Microsoft urges USB driver users to upgrade their consoles to a spring 2010 version or better. Use Xbox Live, a flash drive or a CD burner to perform the firmware upgrade.
1. Configure your USB device after your console's upgrade is completed. With the console on and connected with a working television, plug the USB driver into an available USB port on your Xbox 360.
2. Use your controller to choose "My Xbox" then "System settings." Then choose "Memory."
3. Pick "USB Storage Device" from the "Storage Devices" menu. Choose "Configure now" to ready your device for its first download. Follow the remaining prompts to configure the driver.
4. Save individual game files to the USB driver by accessing the "Memory" folder.
Hope this informnation will be helpful. Thank you for using FIXYA.
Apr 19, 2011 | Microsoft Xbox 360 Console
My xbox work read copy games or originals
Did you try to flash the X-BOX drive with the j-tag exploit, if yes then it must have not run successfully , if you have not dont do it as it will just ruin your console if you donot know what you are doing. Try using a Cd-Lens cleaner as your DVD-Lens might be dirty and could be a cause. Does the disk spin when it is inserted into the drive ?
Clear your system cacheIf your Xbox 360 console can't play multiple game discs, try clearing your system cache. Here's how:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Memory.
  3. Highlight any storage device, and then press Y on your controller.
  4. Select Clear System Cache.
    Note If Clear System Cache is not available, follow the steps in Clearing the System Cache (http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/clear-system-cache.aspx) .
  5. Try to play a game disc.
Disconnect memory units or USB flash drives
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on your console.
  4. Try playing a game.
If all these fail try this
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/disc-drive-wizard.aspx
Mar 04, 2011 | Video Game Consoles & Games
I bought a used xbox 360 and it says to save a game I need to make a profile,but when I try to create a profile it says I need a storage device... for all the $$ this thing costs it has NO internal memory...
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.......
Click here to download repair guide
Dec 24, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
I used my gamertag at my mates and now it wonte let me recover it what do i do ?
if you can get a usb (at least 1 gb) and plug it into your friends xbox, you can put your gamertag profile onto the usb and then transfer it manually. this is the safest way. your usb must be configured to Windows FAT32 file system format (devices formatted for use with other file systems might not work). On your console go to my xbox then system settings, then memory. on the storage devices screen select usb storage device. select configure now (note this will erase everything on your usb) then The Xbox console tests your USB storage device to make sure it will work correctly with the console. If your device passes this test, you can use it as a USB memory unit. to get your gamer profile on there go to system settings, memory then the hard drive, select gamer profiles and move your gamer profile to the usb. you shouldnt recover your gamer tag unless you absolutely have to as any achievements or changes you have made since the account last connected to Xbox LIVE will be lost during the recovery process. once again do not recover your gamertag to a friend's console as a convenience, as you could also lose your saved games!
hope this helps
Nov 28, 2010 | Microsoft Xbox 360 Console
It wont read on my xbox 360
If you already have the Spring 2010 Dash Update for the Xbox 360 console this can be configured( go to Setting up your Xbox 360 with your USB Flash Drive).
The update allows you to configure a flash drive to hold up to 16GB of Xbox 360 games, gamertags, videos, and other information. You can connect two USB storage devices to your console at once.
  • If you don't have it yet, you need to download the update:
To install the update through Xbox LIVE
1. On your Xbox 360 console, sign in to Xbox LIVE.
2. Select Yes, updated now when prompted.
3. When you see the new Dashboard, you're done.
Setting up your Xbox 360 with your USB Flash Drive: 1. Plug the USB flash drive to the Xbox 360 console.
2. On your console, go to My Xbox, and then select System Settings.
3. Select Memory.
4. On the Storage Devices screen, select USB Storage Device.
For detailed instructions you can visit: http://kb.sandisk.com/app/answers/detail/a_id/2777
Nov 25, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Xbox 360 system will not reade any kind of storage format, like hard drive or flash drive in the usb slot.
If you have the Spring 2010 console update installed on your 360 console, you have to configure the USB device it before it is recognized by your Xbox 360 console. Connect your device, go to My Xbox menu, go to System Settings, then choose Memory. From here, select "USB Storage Device", and choose "Configure Now".
Your device will need at least 1GB free storage, and your console can use 16GB maximum of all attached USB storage devices total. Move the slider to configure the space to use & press the A button to set. Your USB device should be listed as a storage memory unit now!
May 09, 2010 | Microsoft Xbox 360 Console
New Xbox 360 Arcade, Memory Problem
go into system settings, memory, and see if it detects the device/storage. the drive may need Formatting.
alternatively try a Memory Card Unit.
On ocassions the 360 may have to update from the gamedisk.
Follow any onscreen Prompts.
Mike @ Compurepair.
Mar 26, 2010 | Microsoft Xbox 360 Console
Storage device not found
Saving a game requires you to have a Hard drive or memory card did you purchase the premium edition xbox 360? you can look on the outside of the xbox 360 box it will give the specs and what came with the system. If the hard drive is not on the list then you will need to buy one the xbox doesn't come with any internal memory like the systems in the past have. you will need to purchase a HD or a memory card. If you have the premium edition let me know ill instruct on how to set it up.
Dec 27, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
