Question about Vizio XVT3D474SV 47 in. 3D LCD TV
Their is a flickering line that go a cross my hole top screen how do I fix this or is it normal
  • 760 Answers
Change your aspect ratio to full. You are on just scan. When on Just scan mode this is normal. They have to have that to be THX compliant. Just change your aspect to full or 16:9 and you will be fine.
Posted on May 18, 2011
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
There's a thin line on the top of my screen and i have sound
Perhaps an easy fix. Remove the back of the flat screen. There will be a main circuit board visible. There will be several capacitors, cylinders with a cross hatch on the silver top. Do any of them look like they have a dimple created by expansion of the internal capacitor material over heating? If you see an expanded top...that's probably your problem. Get your solder gun out and replace that capacitor. You can order a new one off of Amazon. If yours is a 10 volt capacitor, consider replacing it with a 16 volt unit. Generally the electronics companies under design the size of these units. When you replace the capacitor take note of the silver band on the unit and where its placed in the two socket holes....there is a positive and negative hole placement.
Jan 03, 2011 | Sharp LC-32SB24U 32 in. LCD TV
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
A solid horizontal line across middle of screen , sound is normal fixable?
Yes,hits the back plastic cabinate see if the picture flicker back to normal.Know how to slders just find out were is cold solders.Resolders that will fix it.Don't flicker back ur Horizontal IC is dead.Must take it to shop for IC replacement.
Feb 17, 2010 | Televison & Video
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes about half way down the screen.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Dec 06, 2009 | Zenith D52WLCD 52" Rear Projection...
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Flickers and Lines
you have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Mar 21, 2008 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Tv trouble
MOST BE A VERTICAL PROBLEM if the line cross the screen from left to rigth,,, and if the line cross the screen from top to buttom then is an horizontal circuit problem any way you need a tech how ever if you know about tv repair and have somes skill in the campus try resoldering the vertical output IC....good luck and rate me
Jan 20, 2008 | Emerson EWF2703 27" TV
Vizio XVT3D474SV 47 in. 3D LCD TV Logo
204 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
