Question about KitchenAid Dishwashers
Water is still present after cycyle on bottom of dishwasher
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Posted on May 19, 2011
The water is not draining out of the dishwasher at end of rinse cycle leaving a pool of water in bottom of dishwasher
Possible that the drain pump /drain valve is not working . it can be struck or it could have failed. Best is to check the voltage during the program . If voltage is present then pump is faulty but if voltage is not present then the controller board is not working ,possible failure in the board.
check this link for some more help and topics.
Dishwasher
Happy Holidays
Dec 24, 2010 | Neff 24 in. S5456 Built-in Dishwasher
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Dec 13, 2010 | Dishwashers
The lid that you put the cleaner in does not open during the wash cycyle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Oct 26, 2010 | Dishwashers
D/W does NOT drain. Water remains in bottom after cycle is completed
Hi
Oct 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
I have standing water in the bottom after using
Hi
Oct 20, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
1" of water standing in bottom of dishwasher after cycle? what is the problem
Hi
Oct 20, 2010 | Asko 1375 Dishwasher
Water sits in bottom but won't run
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Washing machine leaks at bottom left corner. Water still machine after drain/spin cycyle
My GE washing machine leaks while filling up in the first cycle in the left back corner. Need help!
Jun 16, 2010 | GE Profile WPRE6100G Top Load Washer
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Dishwashers Logo
110 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
