Question about Tricity Bendix TM220W Electric Dryer
My dryer s motor runs and heats up but does not turn, I have looked for a belt but cannot see one
  • Tricity Bendix Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jun 12, 2011
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
My Maytag Performa Dryer model PDET920AYW will heat but drum will not turn. Belt is not broken. Can you help?
It is possible that the motor start/run capacitor has failed, rendering the motor unable to get going. The capacitor will look something like this
http://como-reparar.com/guides/tumble-dryer-turning-find-fault-replace-motor-capacitor/
Jun 16, 2015 | Maytag Dryers
My dryer turns on and reads sensing , but does not turn ....does heat
If your dryer heats yet does not tumble i would be looking for a broken belt..when its heating that means the motor is running,but since i suspect the belt of being broken its not tumbling
Sep 13, 2011 | Whirlpool WED8300S Dryer
Heat works on dryer but won't spin... the drum
heatman101
Jun 28, 2011 | Kenmore Dryers
Hunter, I have A kenmore electric dryer model 110.64121100. My problem is the dryer heats but the drum does not turn. This is a very strange problem. I turned off the timer and heater was still on in the...
Ok check the belt. if broken then make sure the drum turns freel by hand before replacing the bely. Usually dryers wont heat if the motor doesnt go so perhaps the motor is running without a belt. have a look see. Without an inspection its dificult to pin point Good luck
Jan 22, 2011 | Dryers
My whirlpool special edition 3 cycle dose not turn on but it gets heat the belt is fine, it was working fine then one day out of the blue i turned it on and it was not starting noticed it was still heating...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Aug 26, 2010 | Whirlpool LEB6200 Electric Dryer
Belt broken on drive for drum on dryer tm 320w replace same but motor not running fan working ok
  1. Unplug dryer, check electrical connections and inspect wires for corrosion from motor to controls and power control box.
  2. If connections to motor are good, and if the following is safe and practical: disconnect power wires from fan and heating unit, and secure them in a manner which will keep them from contacting anything. Sealing the ends with electrical tape could be a method. Then start the dryer and listen to see if the motor is humming and trying to turn. The motor is probably bad if this is the case.
  3. Look for evidence of overheating motor. Did belt break from wear or age? Or was it heat damage from overheating motor? Inspect belt to determine.
  4. Try turning motor by hand to see if the bearings are shot. A grinding sound could indicate this, or the motor not turning at all.
Dec 16, 2009 | Tricity Bendix Dryers
Dryer heats up but the inside doesn't turn.
a dryer will not turn if the belt has fallen off the motor or if it has been broken    replace the belt
Nov 05, 2009 | World Imports Belle Foret N30002TB...
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
KENMORE DRYER PART NO 696891
are you sure belt not broke remove screws under lint screen and pull top up by releasing clips under edge each corner..is motor running ? also belt may have jumped off idler pulley and motor pulley remove front panel to ck
Oct 24, 2008 | Dryers
Tricity Bendix TM220W Electric Dryer Logo
89 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
