Hi, my wireless internet connection on my samsung r519 keeps dropping off. the blue circle rotates over the internet connection bar - i thin have to manually disconnect and then re-connect and then its good for a while (anything from 1 mon to 1 hour). then it drops agin. im on win 7 do you have any ideas fix this?
    Guru:
  • 485 Answers
There could be a number of causes for this issue. I will give you some tips to see if you can't resolve the issue.
Make sure your computer and software is up to date. Update windows and update any device drivers for your computer. Do a google search by the brand name of your laptop, go to the website and look up Drivers/Software specifically for your wireless card/motherboard.
The problem could be with your Internet Service provider if you are using your home network. The signal could be degraded and they will have to come out and fix that by replacing splitters and lines at your residence.
You could have an issue with your router. If your router is dropping connections there is not much you can do about this other than replace it. You can try to reset the router(you will lose settings and will have to reconfigure). In order to reset, you can press the small reset button on the back of the router and hold it for 10-15 seconds. You can also rule out the router by bypassing it, hooking your laptop up straight to the modem. If the problem goes away then you know the router is most likely the culprit.
Regards,
G33k
Posted on May 18, 2011
How to do a system restore
Have you rebooted the Laptop? shut down, unplug, remove battery, plug in, reboot, the device should install the device. Open Device Manager, look for Network Adapters, open Is the wireless device there? Post results. If no right click network adapters and Scan for Hardware changes. You can find the Wireless Adapter driver here, select the correct OS: http://www.samsung.com/uk/support/model/NP-R519-FA06UK-downloads
Mar 01, 2013 | Samsung R519-53S Notebook
I have installed windows 7 to my laptop but my wireless has been turn off
Maybe it will work again if you install the driver for wireless internet:
Select driver - Windows 7 - Wireless LAN,ATHEROS
Dec 17, 2012 | Samsung R519-53S Notebook
My Samsung R519 cant start message says : Hard drive not found??Help dont know what to do??
Boot into BIOS and see if the drive is listed there. You might have re-connect HD. Worst case is a total HD failure. Good Luck
Aug 27, 2012 | Samsung R519-53S Notebook
My samsung r519 has stopped connecting to the internet
Does the Laptop say it is connected to your wireless router? If not, connect to your router. Maybe the laptop is continuously polling because you keyed the Wireless Network Key/Password in wrong. If it's wrong, it will never connect.
Try disabling the wireless connection, then enable it and see if it connects and lets you out to the internet.
Make sure you are using the same Authentication (None, WEP, WPA, WPA2) as the laptops that you say work.
Apr 08, 2012 | Samsung R519-53S Notebook
Samsung R519-53S Wireless Driver
were can i dowload wireless drive for samsung r519 anyone
Jan 27, 2012 | Samsung R519-53S Notebook
I cant be able to browse the internet using my samsung r519 laptop
It depends on the browser and the network ..
assuming all its ok ..than the internet connection may be faulty ..check to have all drivers for the device you use to connect .The LAN driver for cable connection and the wireless driver .The drivers should be on the cd that came with the laptop ..or download them from the manufacturer's support site ..
http://www.all-driver.com/notebook-driver/samsung-r519-53s-notebook-driver-xpvistawindows-7-download.html
You also have them here ..select the last ones for windows 7 and install them again (the LAN and wireless drivers)
after that be sure you make the connections right ..if you have a static Ip you need to insert them and for that contact your ISP .
Nov 21, 2011 | Samsung R519-53S Notebook
I can't browse internet using my samsung r519 laptop
Usually if the browser do not display the engine or home page , to blame is the internet connection . Depending on what kinda connection you use...check the cards for to be installed proper . To do that open the device manager and look for the network cards..and be sure they do not appear in the list with yellow marks ..If they do ..you need to run again the drivers for them or for the one is missing .
If you do have all drivers..and you use a wireless connection ...be sure you have one ..and the card is enabled..for to enable teh card just press the wireless button and when it is lit it will display the connection ..and you need to open it and scan for networks choose yours and connect .
If you want to get to the device manager just click right on computer icon ..choose properties and (hardware ) device manager ..
If you need teh drivers insert the disk you got from teh manufacturer.the one with the drivers and if you do not have them ..just go to teh support page ..select the model and download them again (also select operation system ) .
have a nice day !
Nov 21, 2011 | Samsung Computers & Internet
I have a samsung r519 laptop my internet connection went down on saturday the man from bt said my wireless switch had been turned off but i dont no where it is.can you help
This is really easy to solve. On your keyboard, you'll see there's a Function button, labelled Fn (probably in blue) near the left hand ctrl (control) key. Hold this and press the key that has a little blue aerial on it (an inverted triangle with a line running down the centre), which is probably the F9 key at the same time. This should activate your laptop's internal wireless adapter. If you'd like to see the manual, you can download it from [here]. Page 68 has more information about this specific problem.
Mar 07, 2011 | Computers & Internet
I have a samsung R519 laptop. What do the BLUE
Thankyou. Afriend has given me a Samsung book which explains.
So my problem is now solved, thankyou.
Jan 11, 2010 | Samsung Computers & Internet
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
