Question about Vacuums
I wish to remove and replace the flex but cannot get into the handle housing? Electrolux contour 88
    Brigadier General:
  • 3,917 Answers
Hi
Please check this links if it helps:-
http://www.ehow.co.uk/how_7769837_disassemble-electrolux-vacuum.html
http://www.ehow.com/how_7706092_replace-electrical-cord-electrolux-vacuum.html
http://www.ehow.com/how_7789946_apart-electrolux-vacuum.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 18, 2011
How do you remove the bottom of the electrolux model 1572E to replace belt?
the discovery electrolux are different. :)
The top comes off, not the bottom like other vacuums.
After taking the screws out, turn the vacuum on its side (vacuum handle to your left, front of vacuum to your right when looking at bottom).
There are two rectangular holes, one on top above the wheel and one on bottom below the other wheel. Place a flat head screw driver in one of the holes and pry gently, pushing handle of screwdriver toward your right. At same time pull up on top plastic of vacuum. Do the same thing for the other side. Top should come off.
Best to you.
Jan 18, 2018 | Electrolux Vacuums
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
Mar 11, 2011 | Electrolux Vacuums
What charge for this service?
Actually there are no hidden screws on your Electrolux Epic model. This is the newer plastic body canister made by Aerus Electrolux. In order to open the vacuum cleaner to inspect the motor, first open the vacuum bag door and remove the vacuum bag. After the vacuum bag has been removed, keep the vacuum bag door open.
The two rubber furniture guards on both sides of the vacuum cleaner are actually what are holding the top housing and the bottom housing together. You'll need to slide both of these rubber furniture guards off in order to open the rest of the vacuum cleaner. They slide forward towards the vacuum bag housing which is why the door needs to be open.
In order to get these slides started, it's sometimes necessary to put a flat head screwdriver in between the back of the furniture guard and the start of the cord reel housing. Right after the rubber starts behind the word Electrolux. Fit a flat head screw driver in this gap, and it's sometimes easier to use a hammer, and hit the screw driver that's on the furniture guard facing the front of the vacuum.
With a little perseverance, you should be able to get the slide started, and when the slide starts to come out past the vacuum bag housing, simply grab the end of it with a pair of pliers, and pull the rest of it out of the vacuum.
Do this on both sides of the vacuum, and you'll be able to separate the two housings, and get access into the motor compartment.
If you have any problems, or would like me to take a few pictures of this being done, I'd be happy to do so. Please just rate my repair as helpful if you found this advice useful. I really do appreciate this.
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Electrolux Epic 6500 Vacuum
Power Cable wires exposed where it enters handle
Part of your question has been cut off by the FixYa system, but I guess you say the wires are exposed where the flex enters the handle. To dismantle the handle, first remove the handle from the machine and, of course, be sure the flex is not plugged in to the mains power.
Look on the back of the handle - you will see a small screw. Undo that screw and remove it, then you will be able to pull the plastic part of the handle out from the metal part. NOTE: it does not come very far out - just far enough so you can separate the two halves of the plastic part. When you've done that, it's only a matter of removing the damaged part of the flex (noting how the wires are routed inside the handle), stripping the remaining flex to match the bit you've removed, and wiring it in. Fit the two plastic halves together again (one hooks into the other at the top), push them down into the metal part and refit the screw. Job done!
If you need more help, just post a reply here and I'll get back to you soon. Good luck!
Apr 05, 2010 | Sebo X4 Bagged Upright Vacuum
There is no power. fuse checked. I have stripped down the vacuum cleaner but still does not work
Almost certainly there is a break in the wire inside the flex. This happens most often just where the flex enters the handle (less often where it enters the plug). If you have any means of checking for electrical continuity, with the machine unplugged from the mains remove the handle and check for continuity between the pins of the plug and the sockets at the end of the handle. If you can't do this yourself, you will need professional help.
If there is a fault in the flex close to the handle it is possible to remove the flex from the handle, cut off the damaged bit and re-wire the remainder into the handle. To have a professional do this may well cost more than just fitting a new pre-wired handle.
Good luck! If you need more help, just post a reply here.
Apr 04, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Electrolux 1572E (Discovery II) How to remove suction motor cover?
Remove the handle assembly by taking the big screw out and pull up on the handle. Remove the four screws where the top half connects to the bottom half. Two on the outside back and two on the inside front where the bag goes. You'll need a long phillips #2 screwdriver. Always have the power disconected. Pull up on the bag housing while twisting it side to side.
Good luck after you get in.
Aug 10, 2009 | Electrolux Vacuums
ELECTROLUX OLYMPIA ONE HOSE
Usually the older hose get replaced, they just weren't made to be repaired, if it looks like something that will come off, then try either warming the sleeve up with hot water or a hair drier to see if you can work it off after it has warmed up.
Apr 10, 2008 | Vacuums
Electrolux contour 1100 flexihead. Z1436
You need to unscrew the screw at the back / base of the handle. The whole handle section will need to be slid backwards. Best way is to unscrew the screw on the rear approx 5 turns and then bump the end of the screwdriver. A few more turns then bump the end of the screwdriver again. The whole handle will eventually slide backwards and fall off. Then unscrew the two screws at the front (near switch) and the front switch cover plate will lift up (hinging at the top). This reveals the incoming wires etc.
Jun 18, 2007 | Electrolux Cleaner Lux 6000 Vacuum
Vacuums Logo
141 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
