Question about Midland F-10 (14 Channels) 2-Way Radio
My walkie-talkies are model midland f-10. 1 will transmit the signal when you talk into it but the other one will only recieve a signal (you can talk in to 1 but not hear out of it, while you can hear out of the other one but not talk through it. The tower sign on the transmitting one has 2 "lightning"signs next to it but when you push the butten they dissapear an dcircles show up on end of "tower". The broken one has the tower but thats it when ypou push the talk butten the circles apear. When you push the talk butten on the transmitting one "lightning" signs apear on the broken one. Thank you for your help
Agent Ken
  • 250 Answers
SOURCE: unsilence
Hello gc0273,
Make sure that both radios are using the same Interference Eliminator Code. The situation you describe sounds like one radio has a Interfernce Eliminator Code activated and the other radio does not.
To access the Interfence Eliminator Code setting on this radio press and hold the MENU button until the code starts to flash, then use the + or - keys to adjust the setting and press the PTT to save it.
Best Regards
Agent Ken
Go Ahead. Use Us.
Posted on Apr 14, 2008
Agent Ken
  • 250 Answers
SOURCE: Constant RX mode on Cobra Microtalk Walke Talke
Hello CleanRightCo,
Many two-way radios have a Monitor function that disables the squelch control. The squelch is what keeps the radios quiet when they are not receiving an incoming signal. However the squelch feature can also cause weak signals to cut out and not be understood, so the Monitor function provides a way to disable the squelch in those circumstances. It sounds like you have the Monitor enabled / squelch disabled on the units that you hear constant static.
For the Cobra MicroTalk 4100 it appears that you enable the monitor by holding down the Light/Max Range button for 5 seconds until the radio beeps twice. You may have activated this function inadvertently. To disable the monitor and re-enable squelch simply press the Light/Max Range button again or change channels.
If this doesn't fix the problem there may be a problem with the auto squelch function on the radios. Or the channel you are operating on may have a noise level that is above the radio's squelch level. You can try changing channels. Or another possible solution would be to activate the CTCSS (Continuous Tone Coded Squelch System) on all the radios. This function will mute the radio's receiver unless a signal is received from another unit using he same CTCSS code. This should keep the units quiet regardless of the noise level on the channel. However all the radios MUST be set to the same CTCSS code or they will not be able to communicate with each other.
Best Regard
Ken
"Go Ahead. Use Us."
Posted on Jul 07, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Posted on Dec 26, 2008
Neto
  • 123 Answers
SOURCE: Midland GTX800 "X-Tra Talk" 2-way radios will not transmit
Are you sure that the batteries are running well?
Try using alkaline batteries just for testing.
Posted on Jan 23, 2009
1HiTech
  • 13 Answers
SOURCE: Can't figure out how to get a "channel" to lock on the handset
Here is a link to the owners manual for the LXT-330 420 Series radio:
http://www.hitechwireless.com/pdf/Midland/LXT-330-420 Owners Manual.pdf
I hope this helps.
HiTechWireless.com
Posted on Mar 27, 2009
Both phones are displaying out of range please advise
Walkie talkies talk to each other. Try transmitting (talk to each other) so they receive a signal first. Do it in the same room. The try for range. It is not much. Even for a GMRS radio, these are low power and short range. Under 2 miles, must be able to "see" each other.
Mar 07, 2016 | Binatone 100 Latitude Walkie Talkie twin...
Do you leav the cobra micro talk walkie talkies on when charging
Also, never transmit with them in the charging cradle. I know, lots do but you risk ruining the radio beyond repair.
Dec 26, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
Nov 10, 2013 | Midland Radio Midland X-tra Talk Frs/grms...
I lost my manuall for my GXT walkie talkie
Look online for the manual, I found my refrigerator manual online,
Jul 04, 2012 | Midland Radio GXT760VP4 - X-TRA TALK GMRS...
One of my walkie talkie has an RX on the display and you can send but you cannot hear the other person. How can I remove the RX as that seems to be the only difference in them. Thank you
depending on what radio you have, they are programmed in different ways, rx means recieve signal
and tx means transmit signal, if you have a mode button, you will have to scroll through it until you
get to the menu that allows you to change the radio transmission. it looks like that radio is only
programmed to receive signals and not transmit. good luck!
Nov 11, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
My roadtrip cobra cb won't talk with my midland gxt radios
What midland is it? if its a gmrs 2 way radio, like a walkie talkie, even tho it has 40 channels, it is not a CB. it transmits on a completely different band.
CB is in the 27mhz band, and gmrs is in the 462 MHZ band.
They will not talk to each other.
Oct 23, 2009 | Cobra Radio Communications
Walkie talkies will talk but not recieve
My experience has been that you are probably on the wrong subchannel on the one that cannot receive.
Apr 08, 2009 | Motorola Walkie Talkies 2-Way Radio
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 02, 2008 | Motorola Walkie Talkie 2-Way Radio
Midland F-10 (14 Channels) 2-Way Radio Logo
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
