Question about Husqvarna Garden
Husqvarna 125L. Starts but runs rough for few seconds then fuel runs over the fuel tank from under carb. Has very few hours of use. 2 years old and haven't used in 1 yr. Help!!
  • Husqvarna Master
  • 1,807 Answers
Carb gasket may have gone, may also be a split fuel line.
Posted on Aug 03, 2013
panilling9
  • 284 Answers
SOURCE: What are the factory settings for the
find L on your carbruetor and turn it clockwise 1/4 turn to see what difference it makes
it should begin to idle by itself?
zama carb. 1 turn out from closed
walbro 1and 1/4 from closed settings are only preliminary
Posted on Jun 14, 2009
SOURCE: Craftsman mini tiller starts good but will not idle nor run fast
i'm having the same problem. cleaned carb but didn't help. I found that if I spray starting fluid on the gasket between the carb and the motor it speeds up. I'm going to try to find a new gasket, I can't tighten it anymore.
Good luck
Posted on Aug 14, 2009
SOURCE: husqvarna 125L quit running, it runs then shuts off
Check the gas line. The Husqvarna is having a problem gas additives causing the gas line to deteriorate and colapse.
Posted on May 14, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
  • 2210 Answers
SOURCE: My Husqvarna 128ld trimmer will run but only at
guys,
the d shaped tool is also carried as an MTD part. see your local dealer.
If not google walbro d cut tool ad see what you get. They're on solo
chainsaws as well
Posted on Dec 03, 2011
22 hp in husqvarna mower, will crank and run 2 or 3 seconds and quit, have changed fuel filter and checked for water in gas
If it starts and runs, even for 2 seconds, it's more likely to be a fuel problem than an electrical one...I'd first suspect the carburetor float/valve being gummed up, especially if you've left it sit for the winter with gas in it...if that isn't it, then remove the gas tank and check the tank and lines to the carb for obstructions...
Jan 01, 2015 | Husqvarna Garden
Husqvarna 125l carb problems
Check the fuel lines. Ethanol in the gas swells the old type fuel lines.
Jul 17, 2014 | Garden
It starts and runs for about 1 minute then it quits running Husqvarna 125L
check the primer bulb still has fuel in it,check the fuel lines and the tank vent
Feb 04, 2011 | Husqvarna Garden
May 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Have an old husky 40 probably about15-20 years old. Was running but stopped, could crank back up but when throttle was applied it stopped running. Inspected fuel pickup line to carb and it was broken...
On 2 cycle motors, the carb actually has a return line to the tank and this pressurizes the tank to bring the fuel into the carb. You may need to take the carb apart and chec the diaphram inside to make sure it's not cracked. This is what creates the pressure.
You should be able to purchase a carb rebuild kit from a local small engine repair shop. Also check your air filter and make sure it's cleaned and reoiled as needed. Change the spark plug as wel.. when they sit for long periods of time, they tend to not fire as well due to the chemicals it's exposed to.
May 18, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 55 Chainsaw (1999) - Runs OK for 1 minute then stalls
I think your on the right track
Blowing compressed air through your tank vent
is great but it is way more air than the natural asperation
that the saw pulls on it own
I would replace the vent cap and also look for a pinched fuel line between the fuel tank and the carb
Apr 07, 2010 | Husqvarna Chain Saw 20" Bar
Garden Logo
103 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
