Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
How do I change the frequency on my v tech 5.8 phone?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Since you declined to specify the model of your VTech phone, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to get a copy of the manual.
Posted on Sep 17, 2011
Cant remember my code for Master Reset and Clear what must I do
Pleas e do the following step
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
You can change GSM frequencies to 900/1800 by entering the enginnering model.
Following the below steps:
enter menu and press 048263* quickly,
then you will enter the secret engineering menu under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650,
press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.
press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.
You will receive an extra 50 msgs memory space.Switch phone off and back on.
Hope this helps.
Thanks for using fixya .
Jan 26, 2011 | Motorola Mobility V360 Cellular Phone
Tip
MOTOROLA TIPS
Motorola Secret Codes
IMEI number:
*#06#
Enable EFR:
Function :
Change pin:
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Important!
Try these codes at your own risk! We don't accept any complaints.
Some of these codes may not work
on Sep 27, 2010 | Cell Phones
Tip
Motorola secret tips
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
on Mar 08, 2010 | Cell Phones
My motorola v360 unlock code and security code has been changed and now i cont entre my phone please help?
hello,
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 20, 2011 | Motorola Mobility V360 Cellular Phone
Special code of motorola nextel i836
hi,
Here are the codes
1) to find out the IMEI number:*#06#
2) this is used to lock keys Press together *7
3)Select phone line - (use this to write things below the provider name):
4)Add phonebook to main menu:
5)Add messages to main menu:
6)Copy SIM memory (phonebook menu):
7)Eng Field options (main menu):
8)Slow (Frequency of search menu):
9)Medium (Frequency of search menu):
10)Fast (Frequency of search menu):
11)Enable EFR:
12)Function :
Change pin:
thank you for using fixya.have a nice day :-)
Jul 24, 2010 | Motorola Mobility i836 Cellular Phone
Change freqauncy from 1800 to 900 .It do not support sim cards.
I do not understand, The phone is Tri-Band GSM and Di-Band WCDMA so that is 5 bands. It runs on the 850/1800/1900 MHz GSM/GPRS/EDGE frequencies as well as 1700/2100 MHz UMTS/HSDPA 3G frequencies. It does not have the 900MHz band as it is not used in the United States. The European version of the phone comes with the 900MHz band instead of the 850MHz band.
May 03, 2010 | Sony Ericsson TM506 Cell Phone
Can you change the operating frequency of a Samson
No, the Stage 5 series are fixed-frequency units. They come in a variety of channels (the new 200Mhz range model has 28 different ones) but they're factory-set, and not programmable, so the frequency you pick when you buy one is the frequency you're stuck with.
Apr 07, 2010 | Samson Stage 5 / CO5 Professional...
5808 drops call and starts searching for base
Got a wireless router? Change channels on the router off Ch6, the default channel and that may help your phone communication to the base station. I have had wireless phone customers lose their wifi when their phone rings, same frequency or intereference on that frequency.
Feb 13, 2008 | Vtech 5808 Cordless Expansion Handset
Unlock codes
here are set of code that you can apply and play with. You should have included the model of your cellphone but i'm hoping that this would help.
Enable EFR:
Function :
Change pin:
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Jan 04, 2008 | Lands Phones
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
32 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
