Question about John Deere Garden
I can start the mower with the break engaged, however when I take my foot off the break the mower quits. I have checked the seat switch by putting the two wires together and the same continues. I have the mower deck off the tractor and looked under the tractor and see no wires broken. Help Dave
  • 24 Answers
The two wires on my seat switch need to be apart, not together. This is kinda a guess, as all mowers are not the same. Good Luck!
Posted on May 18, 2011
Testimonial: "That was the problem...Thanks I will haveto go and buy a new seat switch...Now I can mow that tall grass again...I appreciate your help. Dave"
  • David Lyons
    David Lyons May 18, 2011
    You are the best Thanks Dave
  • Jeff Johnson May 18, 2011
    You are more than welcome. As that great philosopher Red
    Green says, "we're all in this together".
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
With my foot on the brake, I turn the key and the mower engine starts. Taking my foot off the brake, the engine stops. There is no change in mower engine speed when I step on the gas. What do I repair. ...
Check your safety switches for proper operation. For example with the brake engaged it is posible to start the mower without a rider, if the seat safety switch is bad, then when you let off the brake it does not signal a rider in the seat and will kill the engine. I would start with the seat safety switch, try disconnecting it and then start and try to mow. If you are able to then you know that is where the problem is.
I hope this helps you out.
Aug 02, 2011 | Garden
Murray ride-on lawn mower model 155/107 (15.5 HP Briggs & Stratton engine). Engine starts o.k. but cuts out as soon as the hydraulic clutch is engaged via foot pedal. ie foot on clutch to start...
two possible problems. check power from safty switchs, put the lever down under the seat and rock the back tires back and forth until you here a click. then try again. a safty swith is giving you problems
Apr 25, 2011 | Garden
Husqvarna YTH 2042 lawn tractor It starts OK, but as soon as I take my foot off the clutch, it lugs and quits. Same thing happens if I start to engage the clutch lever, even with my foot still on the...
If it really 'lugs', meaning the engine gradually chugs slower and slower as if it's struggling, then it could be a belt problem, but I'm going to guess it just quits, which suggests a problem with the seat safety switch. Look under the seat, take out the safety switch, and tape it in the pushed-in position. See if the tractor runs now. If so, the switch is the culprit - either it failed, or the mounting is wonky so it doesn't activate when you're in the seat.
Jun 05, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
When you engage the mower deck the mower will die and as long as you don't engage the mower deck it will not die.
Check the seat switch for propper connection and position. Also, check any wiring that may be attached to the mower deck. In an extreme case, the pto switch or foot pedal switch may be defective, but mostly unlikely.
Nov 23, 2009 | Garden
Engine dies on lawnmower if foot not on brake
The problem seems to be that the mower seat switch does not "recognize" that an operator is sitting in it.
The 1000 series does not require an operator to startup. Does not require an operator for it to run with the brake on. But it requires one to drive or mow, and it isn't recognizing you so it shuts down, make sense?
The seat switch (for whatever reason) is the issue.
Now, most LT tractors in the 1000 Series use a seat switch that is located under the left front of the seat. The wires connecting to the switch are quite crude and can get snagged by a tree branch or bush and come unplugged. Check these first.
Second possibility would be the ingition switch itself. It contains a module that controls, among other things, the safety circuit. Thie would need to be diagnosed at a reputable, certified Cub Cadet Dealership. The good news is this replacement isn't terribly expensive (if it turns out to be the issue).
My gut tells me it is the seat switch . . . However, Reply with "Add Comments" option if you need further info.
Hope this helps,
Dolf-
Oct 16, 2009 | Garden
Craftsman yard tractor runs but take foot off brake it dies.....
Check the under seat switch. The switch sometimes fails and this cuts the ignition except when the foot brake is down. You can use jumpers across the switch wires to test it.
Apr 18, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
104 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
