Question about Asko 24 in. D3120 Dishwasher
Asko d3120 i hear the dishwasher running ( the cycle i s not running just the sound of it )and it wont shut off unless i unplug it i cleaned out all the water and the drain hose is clear i pressed the on/off button together with the cycle on button to no avail.
  • 2 more comments
  • freidahecht May 18, 2011
    where is the drain well? do i slide out the dishwasher to find it. there is a little water in the bottom of the dishwasher filter
    also you mentioned water in the bottom panel how do i get to that panel?
  • freidahecht May 19, 2011
    where is the drain well? i took off the kickplate but i dont see anything there.
    are you sure you sent me the correct link I dont see anything about dishwshers. its intermatic.
  • Asko Master
  • 17,130 Answers
If what is mentioned is correct to me, the motor or pump is running at times and you can hear the humming when the machine is plugged on. Your resetting also does not help to get the machine to run the program. It seems to me that the error is in the main program controller unit. It is possible that the processor in the unit has errors and has hung up. Alternatively the processor can also have a corrupt memory and so does not run the desired program.
So if the resetting as done by you does not help , then the controller unit must be changed.
Also check the panel , the connections to the drain and inlet and the door switches before the main controller is confirmed.
Posted on May 19, 2011
  • 4,323 Answers
Hi
This could be due to a faulty motor or control panel. Sometimes, the spray arms doesn't spin due to blockage or low water pressure. Check for any stuck food pieces stuck near the pump impeller. Let me know if there are any blinking lights or error codes.To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Hope this helps... Please post back if you need more information. Daniel
  • Asko Master
  • 19,396 Answers
Hi.
Try first disconnecting power cord or tripping the circuit breaker. Power reset can sort out a jammed control module.
If there is no inlet (no water getting in), then the pressure from inlet hose, the water inlet valve, and the overfill switch must be tested. Water valve is tested reading Ohms at valve solenoid. If the multimeter reads open (Ohms infinity), then the valve must be replaced. (see here how to test). If valve is OK, then the overfill switch (float) must be tested. A way to test the float switch is by jumping its contact and starting a cycle. If all those parts are OK and there is NO water getting in, then the problem is the control module.
If the appliance does not even start cycling, there is noise, and there is water inside the appliance, then the problem is usually overflow detected. The noise is the drain pump starting from beginning of the cycle.
If the dishwasher bottom looks dry either there is water trapped in the corners or in the bottom panel, or the drain hose is set incorrectly, and water is flowing back from the drain line, triggering the overflow device. If there is no water and drain hose is fine you will check the overfill device for faults.
Pull out the dishwasher and check the drain hose height and elbow. Ensure that settings are as specified in the user manual. If elbow height is incorrect you get water flowing back from drain inside the dishwasher. That is detected as overfill.
Remove the drain hose and put it in a bucket, then try tilting the dishwasher 45 degrees backward, secure it safely (ask help if needed) and start cycle, so that water trapped at the bottom can be released. Put the drain hose to correct settings and put back the appliance in place if this solves the problem.
If that does not help, then parts must be tested.
Check the drain well again.Open the housing, and remove water present in there . The overfill switch is connected to the float and can also be responsible of the problem. The switch itself can be tested jumping its contacts or using a multimeter to read Ohms at switch contacts. With contacts jumped no overfill will be detected and machine will start working (stop cycle manually after machine begins filling). Alternatively, remove the part and read Ohms while operating the float arm. The switch must change from a couple of Ohms to infinity (overfill) while you manually operate the arm.
If that does not help, go for the rest. Do not replace parts without testing. Check again inlet hose, check spray arms and impeller. Next step would be reading volts from CCU (central control module), and eventually replacing the control module
Try first tilting the appliance and checking the drain hose.
Disconnect power before performing any maintenance operation.
Regards.
Ginko
Posted on May 18, 2011
  • 1 more comment
  • Ginko
    Ginko May 19, 2011
    Hi.
    To access the bottom you remove the lower rack, the spray arm, and the arm support. This is done
    removing a couple of screws. Once parts are removed, inspect
    the drain impeller and remove water.
    Instead of doing that do the rest I suggested and drain water from drain well. That should be enough to fix the problem.
  • Ginko
    Ginko May 19, 2011
    The drain vell is the hole at the bottom. Please see page 9 here with complete disassembly.
  • Ginko
    Ginko May 19, 2011
    Hi.
    I see that you passed the question to a different expert.
    That also leaves me negative feedback.
    You can use parts manual and my comments.
    Goodbye.
    Ginko
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
Havnt used my dishwasher in 2 years on account of saving water. now when i push the start button some water flow into machine for a few minutes and then just stops. manual says to clean filters and drain...
Try pouring water from a bucket through the front. maintain the level. It should not overflow.
Run a empty cycle. If there is a air block it will get cleared.
Sep 08, 2010 | Asko 24 in. D3120 Dishwasher
Asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
Doesn't shut off
i think you are hearing the drain pump going. take the bottom front panel off so as to expose the bottom tray. yoy willprobably find this full of water. mop water out and it should work. if fault reoccurs then you have a leak.
turn power off first
Sep 02, 2008 | Asko 24 in. D3120 Dishwasher
Drainage Problems
Turn off the dishwasher by pressing the on/off switch on the top left of the dishwasher. Wait 5 seconds. Press and hold the program button on the right side of the front of the dishwasher. As you are holding the program button, press the on/off switch again. Release both. This should reset the machine
Apr 13, 2008 | Asko 24 in. D3120 Dishwasher
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Dishwasher fault
I got this with another dishwasher. On that one it meant the water wasn't feeding into it (tap switched off, kink in inlet tube, etc.)
Feb 16, 2007 | Asko 24 in. D3120 Dishwasher
Asko 24 in. D3120 Dishwasher Logo
199 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
