Question about HP Audio Players & Recorders
How to access speakers on my laptop. - HP Audio Players & Recorders
  • HP Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 18, 2011
How do I access/clean keyboard toshiba p55t-a5116 with harman kardan
You can remove the keyboard and then blow everything clean with canned air. Go here for help - http://cpufandeal.com/toshiba-satellite-p55t-a5116-laptop-cpu-cooling-fan.html
Dec 30, 2014 | Toshiba Satellite Computers & Internet
Cannot unmute hp pavillion dv7 laptop
find the speaker icon, bottom right, then right click to access adjust audio properties then select voice, and then volume, and you can unchecl the box with mute
Nov 11, 2012 | HP Pavilion Laptop dv7-1025nr
In my laptop leftside speaker is not working. i can hear from only right side only. Note: if i insert head phones i can hear both side on head phones. working good on headphones. i need to hear from...
If your headphone confirms the working on both sides then it is confirmed that the amplifier is working and the fault is with the speakers.
You need to open the laptop covers and get access to test the speakers, if there a possible line break or connection fault on the speakers, if not the speaker must be replaced with the same type.
Test using a multimeter, open the board carefully without damaging or get help to check this out.
Sep 08, 2011 | Computers & Internet
Cannot get volume to come on my laptop
What is the actual problem? Are you not having any sound or you are not having the Volume Icon on your Taskbar? Please mention the actual problem.
Dec 29, 2010 | Acer Aspire 6930-6771 Laptop
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
In my laptop my left side speaker got damaged. it produces a noise along with playing sounds. what can i do?
if you have stereo speakers then you can adjust the fade so that it plays sound out of the right speaker only. click on the sound icon in the system tray (bottom right of the screen) to access your speaker's settings
Mar 01, 2010 | Acer TravelMate 5720-6635 Notebook
Windows 7 cant hear 5.1 surround sound through laptop audio jack
Are you sure that the soundcard supports 5.1 on your laptop?
Dec 13, 2009 | Computers & Internet
Stereo Speaker troubleshooting
It sounds like the audio jack itself has internal damage. Depending on how it is mounted on your laptop case, or possibly on an internal circuit board inside the laptop; it might be possible to repair the jack or replace with a new 1/8" audio jack. Some soldering skill may be required after disassembling the laptop and getting access to the jack.
Jan 12, 2009 | Computers & Internet
My Philips SBP1100 speaker' volume is not loud enough
Were they ever loud? If they weren't (which is my guess - judging by the picture) is that they are low wattage which essentially means that they are not intended to be loud. They are most likely to be used as a small compact, low-noise speaker for a smal MP3 player where high (club-vloume) wattage/volume is needed. If they used to be loud check the volume control on your laptop and check each and every setting that there is. One stupid little setting could be a big difference. Audio Properties in the control pannel could be helpful but don't mess with those settings in the control pannel unless you are almost positive as to what they are and what they do. You could cause yourself a bigger problem. Remember that most laptop speaker outputs are actually for headphones and are not intended to go super-high as they are designed for headphones and not to hurt ears at high volumes. Hope this helps. If not try checking back with me. Best of luck. Bonne chance!
Mar 09, 2008 | Philips SBP1100/37 Portable Speaker System...
22 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
