Question about Sharp AR-5320 Black and White Copier
The machine indicated replace drum and the drum was replaced what code do i need to clear or stop indicator from blinking in ar 5520
    New Friend:
  • 66 Answers
Press # interupt C interupt then press 20 start 1 start, then press ca, then press 42 start 1 start you can reset your machine , if any queries please feel free to contact , rate this and please vote for this so i can become in to expert catogory
Posted on May 18, 2011
CH blinking in sharp photo copyier model AR 5520
check if the toner is insert or check the doors for the machine both the front and side door door
Nov 05, 2016 | Sharp AR-5520N
SHARP AR 5520 keep displaying TONER INDICATOR ALARM MESSAGE whenever I switch on the copier. And even if there is toner, the message keep displaying. So what is the problem?
Dear
The ink cart. is dual component one is drum unit and other is toner unit. You may go to system information there consumable information which indicate the status of the both and according to that replace the chip of the respective cart.
Thanks.
Jan 12, 2015 | Sharp Office Equipment & Supplies
While starting the xerox machine SHARP AR 5316 , indicator is showing 4 and blinking everytime, unable to take the printout
I'm going to guess that if you watch the display closely, it is alternating between an "H", and a "4". If that is the case, you have an "H4" error code. This is a fuser error and can either be a freak out from the machine, or an indication of something serious. I would recommend resetting the code and seeing if it comes back. To reset the code, turn the machine on and press "#" -> "Interrupt" -> "Clear" -> "Interrupt". Doing this should put you into service mode, where the display will show a blinking double dash (--). Enter 14 and press the green start button, just like you are trying to make 14 copies of something. At this point, the machine should restart itself and hopefully the error code will go away. If the error code does not go away, or recurs on a fairly frequent basis, I would recommend contacting a professional service technician.
Feb 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Need to replace drum and developer maintainance
If you are getting that message and the prints and copys still look good , just do this.
Press # * C * and that will put the machine into diagnostics.
Enter the number 24 and press start, That will get you into maintenance resets. Then enter 06 , press start, then while still in 24, press 7 and it will reset the developer.But 24-06 and 24-07 should clear the count and return the machine to normal. The developer and drum will normally run longer than indicated by the counter.
Jul 16, 2010 | Sharp AR-M205 Copier
My AR M160 digital imaging copier keeps blinking with 4H showing and I cleared the paper jam, all intact, and now nothing but the blinking 4H. please advise
H4 (and other) Error Reset Code:
Press "clear" "interrupt" "0" "interrupt" in succession and machine will blank off
Using the numeric keypad make the display read "14"
Press the "copy/start" key
Good Luck
Nov 09, 2009 | Sharp AR-M160 Black and White Copier
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier sf 2530
Reset the developer by pressing C-CA-0-C - 83-5
May 16, 2008 | Office Equipment & Supplies
SF1118
You need to clear the developer counter. Simulation 24-6.
Jan 25, 2008 | Sharp AR-207 Copier
Sharp AR-5320 Black and White Copier Logo
328 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
