Question about Cobra GPS
What is dynamike gain cotrol on a cobra cb radio
  • Cobra Master
  • 3,287 Answers
Dynamike Gain Control varies the microphone sensitivity. When set fully clockwise, it is very sensitive - and will be able to "hear" background noises easily. This position also can cause your voice to be distorted or garbled when approaching maximum under the right conditions as well as causing "bleed over" to adjacent channels. When set to minimum, you will need to speak clearly and directly into the microphone to be heard. Most people find a setting somewhere in the middle works best.
You should adjust the level to suit those that are listening to you by asking them if it sounds OK. This prevents them from having to turn their volume down whenever you speak. In a "one-to-one" conversation it is not as noticeable. The trouble comes when 3 or more are conversing. The third person's audio may be low or normal - and the listeners set their radio's volume so that they can hear that person easily. Then you transmit with booming mic audio and everyone scrambles to turn down the volume to save their ears / speakers. This can be very frustrating for the others having to constantly adjust the radio volume whenever you speak.
I hope this helps and good luck. Please rate my reply - thanks.
Posted on May 18, 2011
I put a mosfet irf 520 final kit and a swing kit in my cobra 25 ltd now i have a 40 watt radio but have run dynamike all way up ...
I believe that your installation is faulty. Check for any shorts, solder bridges, and that instructions were followed correctly.
Feb 27, 2015 | Cobra25-LTD40-Channel CB Radio with...
Its a cobra 25ltd when i key the mike sometimes it hangs keyed up and does it with defferent mikes so the mike is not my problem.
take some electrical spray cleaner and lightly spray the inside of the radio where the mic plugs in. could also be a keying diode.
Jan 04, 2013 | Cobra 25 LTD 40-channel Classic CB Radio...
Meter drops when pushing mic
some one tuned their radio to the wrong side of peak and now you have downward modulation .Try re-tuning it back to to its original settings and if you get it back don't mess with it unless you know what the shell you are doing.
Sep 30, 2012 | Cobra 25 LTD 40-channel Classic CB Radio...
What is rf gain cotrol on a cobra cb radio
Rf gain on a cobra 29 is the same as on any other radio. When you turn the knob all the way to the right the RF increases to draw in signals that are far away nut if you turn it to the left only the nearest stations will be picked up.
Sep 22, 2012 | Cobra 29 LTD CB Radio
Im having a problem with the mic side of the echo input and output side
rip it out and get an external noise toy then you won't have these problems.
Aug 18, 2012 | Cobra 25 LTD 40-channel Classic CB Radio...
I can recieve but i cant transmit have new antenna and new mic
Check that your mic gain or dynamike knob is turn clockwise if it is full counter clockwise you will have no modulation with your tx power.
I would like to help but one sentence describing your problem can lead to a vague solution.
Be aware that not all 4 pin mikes are wired the same.
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Aug 28, 2011 | Cobra 29 LTD CB Radio
I am a new Truck Driver and I had given to me a good used Cobra 29 LTD CLASSIC CB radio for my Truck. It is missing the owners manual. Can you please tell me what I need to know about the settings on the...
I have the same radio as well. If you are running a "stock factory mic".....do this:
VOLUME: set to your comfort
SQUELCH:all the way to the left (if you don't mind hearing everything other wise adjust to the right to illiminate noise)
DYNAMIKE:If you have a factory mic or "noise canceling mic", turn all the way to the right (unless it squeals and then turn the mic gain down slowly until the squealing stops)
RF GAIN:that is your "receive" and I always turn it all the way to the right to maximize reception! In my opinion, this is the dumbest knob ever made since why not hear as good as you can??? thats what the SQUELCH is for!
DELTA TUNE: IT IS "USELESS!!!
SWR CALIBRATE: don't ever trust it! ALWAYS USE A GOOD SWR METER "IN LINE"
Now as for the "SWITCHES"
The top left switch is the SWR and as I stated, do NOT trust it and leave it on "S/RF (TOP)
SWITCH TWO: If you have it on OFF, you may get allot of engine spark plug firing noise so I run mine in the "middle" (ANL)
THIRD SWITCH: CB
FOURTH SWITCH: Brightness is to your liking!
There ya go! You can always set the switches to your liking and comfort.
"WILDCAT" IN LAURELVILLE OHIO
Dec 24, 2010 | Cobra 29 LTD CB Radio
Dynamike bettery
Use a stack of hearing aid batteries they are about 4$ a package.
Jul 18, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cant find 7 volt battery for dynamike plus cobra
At a pinch you can use 5 x LR44 button cells, yes that does add up to 7.5 volts but that's near enough, the 5 cells on top of each other are exactly the same size height and width as the 7 volt battery. I am using them in a "Telex" mike
Gray
May 26, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Old dynamike plus wiring for a super star 3900
1-Shield
2-White
3-Red
4-Black
Check the mike plug to make sure that none of the wires have broke off.I would also check the mike cable with an ohm meter.
Jan 02, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
GPS Logo
2,047 people viewed this question
Top Cobra GPS Experts
Steve
TO Lady
Are you a Cobra GPS Expert? Answer questions, earn points and help others
