Question about Estate Dryers
Having trouble changing the cord on my dryer, i had went to the store and bought a new electric cord because i needed a 4 prong cord and it had a 3 prong. So when i took it apart there are only 3 wires and on the new cord there are 4 wires there is a white, red, black and green. there is only a place for a black, red and white on the dryer
  • 4,340 Answers
The final wire goes to the case. Anywhere is fine. Much safer with 4 wire.
Posted on May 18, 2011
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
I would like to change the electrical plug on my dryer
The outlet or the cord? You can purchase 3 or 4 prong cords at any Home improvement store. There is usually an extra screw at the terminal block for just that.
Jul 06, 2010 | Kenmore Dryers
My Whirlpool dryer has 4 prongs but my socket only has 3 slots
change the cord out. you can get one at local home improvement store or appliance parts store or most hardware and appliance stores.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208577188.pdf
Jun 07, 2010 | Whirlpool LER5636P Electric Dryer
I have a wall outlet that is made for a 4 prong dryer and i have a dryer with a 3 prong, i went to the store and bought a new cord besides knowing its for a dryer do i need to know anything else, i bought...
When you put the cord on the dryer,the white wire goes to the center wire terminal. Black and red go to the 2 outside terminals right and left. The Green ground wire attaches to a ground screw outside the terminal cover.
Oct 08, 2009 | Frigidaire FEQ332E Electric Dryer
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
New house requires 4 prong plug for dryer...mine has 3...bought new cord...How to wire it?
The old three prong, the vertical prong is neutral (white wire), the two slanted are 220 volts. The new plug, the extra prong is ground (bare wire). Shut off the outlet at the breaker panel, and remove the outlet to examine the wiring to it. It should be as above--the 220 volt wires are red and black or black and black. The ground wire is bare or green insulated. Inside the dryer case, tie the green and white wires to the dryer case, and tie the two outside wires where they went with the old cord. Check with an electrician if you are unsure about this.
Jul 16, 2009 | Dryers
How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Apr 23, 2009 | GE DVLR223 Dryers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
I hope this helps you. Let me know if you still have questions.
Nov 11, 2008 | Frigidaire GLER331A Electric Dryer
Dryers Logo
42 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
