Question about Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive
ACOMDATA 250 I have a 250 that was working fine on a Windows machine.  I moved it to my MacBook to copy some files for the friend with Windows and I loaded the HD Security password program fine.  When I double click it to enter the password to mount on my MacBook OS V 10.5 it says "no device found" and never prompts for a password. The "CD" partition shows up immediately when I plug into the USB port on the MAC
  • petertbender Aug 25, 2008
    Same here!
  • Anonymous Feb 06, 2009
    moved from my laptop to a new mac cant open it up on my new mac nothing to put my password on
I have the very same problem than the one posted by gyoung826 on Aug 14, 2008. My HD is an Acomdata 160 GB, HybriDrive 2,5
Posted on Aug 23, 2008
N723 drives
try opening in a linux machine and you should have all the hard drive files still on there ready to be used and take them and then reformat you hard drive once you have moved your files to a safe place. and then format back to fat32(works on both mac and windows although limit is only 4gb single file sizes are allowed) or ntfs (only works for windows machines)and copy and paste files back onto the drive. It may already be in NTFS format if so copy all files on a windows machine and save safely then reformat the harad drive into Fat32 :D movies shouldn't be bigger than 4gb each so any files that are smaller will be fine
Oct 30, 2013 | Computers & Internet
Hi, my macbook stopped reading my HD and I was wondering how I can get my files off the HD and back them up on my computer
First determine if problem is with your macbook or the drive. Does the drive work on any other computers? If not, then the problem is either the drive or the Acomdata enclosure holding the drive. You'll need to get a usb HDD dock, extract the harddrive from your Acomdata drive and plug the drive into the HDD dock. If your mac is still unable to read the drive, the drive itself is probably not working anymore. If you're a novice and have never attempted data recovery before, I would recommend a data recovery service if it is important that you recover your files. If the the problem is with the drive, there may still be a good chance your files can be recovered but only if you know what you're doing. You don't want to run the risk of ruining that chance and attempt this yourself if you don't have the proper tools or knowledge.
Mar 22, 2011 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
My acomdata 250 GB freezes and does not allow files to be copied and or moved back to desktop computer or to new files within the 250 external drive
there are three main reasons for a hard drive to freeze
up 1. you have reached the capacity of the drive or 2. the drive heads are worn to the point where the drive can not boot up to the PC , meaning the heads need
to be replaced 3. the interface between the unit and
the PC 2.0 high speed will not work into a 1.0 USB
then you have several minor things that can happen
like the degeneration of the cables that are being used , a quick remedy is to go to my computer
right click on the drive compress the drive to save space then do a clean on that drive and also sometimes the HDD needs to be reformatted .
Jan 15, 2010 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
ACOMDATA 160g E5 compatability
By default, the disk is formatted as FAT32, a format that bothe the MAC and PC understand.
Dec 13, 2008 | Acomdata HybridDrive E5 Hard Drive
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
Firewire problem I think - I have a Sony Vaio laptop, the firewire port is 4 pin, it is connected to a LaCie CD Burner via 6 pin and the burner is daisy chained to a AcomData external hard drive via 6 pin....
If the hub has an external power supply it migh do the trick. That way you can have a backup port if needed.
Make sure the hard drive isn't connected to the hub. Sometime windows doesn't see it when its connected to a hub.
Jul 14, 2008 | Computers & Internet
My harddrive will not save files larger then 4 GB
What is the filesystem format on your external hard drive? there are limits on certain file systems, like maximum size of a single file in fat32 is 4gb. let me know the filesystem on your external hard drive and i will try to consult a few friends for you. regards
Apr 18, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive Logo
265 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
